May 12, 2020, 17:04 |
Error when running interFoam in parallel
Carlos
Rep Power: 6 |
I was running interFoam simulations in parallel with no problem until yesterday, that I got the following problem: Code:
cmoreno@clufa01:~/prueba$ mpirun -np 4 interFoam -parallel | tee interFoam.log [clufa01:24393] opal_os_dirpath_create: Error: Unable to create the sub-directory (/tmp/openmpi-sessions-cmoreno@clufa01_0/51976) of (/tmp/openmpi-sessions-cmoreno@clufa01_0/51976/0/0), mkdir failed [1] [clufa01:24393] [[51976,0],0] ORTE_ERROR_LOG: Error in file util/session_dir.c at line 107 [clufa01:24393] [[51976,0],0] ORTE_ERROR_LOG: Error in file util/session_dir.c at line 402 [clufa01:24393] [[51976,0],0] ORTE_ERROR_LOG: Error in file ess_hnp_module.c at line 638 -------------------------------------------------------------------------- It looks like orte_init failed for some reason; your parallel process is likely to abort. There are many reasons that a parallel process can fail during orte_init; some of which are due to configuration or environment problems. This failure appears to be an internal failure; here's some additional information (which may only be relevant to an Open MPI developer): orte_session_dir failed --> Returned value Error (-1) instead of ORTE_SUCCESS -------------------------------------------------------------------------- Anyone knows how to fix it? Thank you beforehand, Carlos |
May 13, 2020, 16:00 |
Herpes Free Engineer
Rep Power: 12 |
Hi
- Could you please retry to run your case? - If the error persists, can you attach the last few hundred lines of log file?
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
May 14, 2020, 07:36 |
#3 | |
Carlos
Rep Power: 6 |
inside the .log file is the following: Code:
-------------------------------------------------------------------------- It looks like orte_init failed for some reason; your parallel process is likely to abort. There are many reasons that a parallel process can fail during orte_init; some of which are due to configuration or environment problems. This failure appears to be an internal failure; here's some additional information (which may only be relevant to an Open MPI developer): orte_session_dir failed --> Returned value Error (-1) instead of ORTE_SUCCESS -------------------------------------------------------------------------- Also when I type "cd + start of the folder name" in the console and I press tab (to not have to write the full directory name) it doesn't work: Code:
cmoreno@clufa01:~/prueba$ cd p-bash: no se puede crear un fichero temporal para el documento-aquí: No queda espacio en el dispositivo It is strange because if I try to run the simulation without using mpirun it works perfectly (just typing interFoam), so I think it's not a problem of space. |
May 15, 2020, 08:40 |
It looks like your root directory is full.
Please check if there are large tempory files in /tmp or other parts of your root directory that you can remove. You will need root access to remove those of course. Regards, Tom |
May 15, 2020, 09:51 |
#5 | |
Carlos
Rep Power: 6 |
I'm not used to work in Ubuntu. How do I check if the are large files in /tmp and remove them? I typed df -h and I got this: Code:
cmoreno@clufa01:~$ df -h S.ficheros Tamaño Usados Disp Uso% Montado en udev 3,9G 0 3,9G 0% /dev tmpfs 796M 81M 715M 11% /run /dev/sda2 11G 11G 0 100% / tmpfs 3,9G 0 3,9G 0% /dev/shm tmpfs 5,0M 0 5,0M 0% /run/lock tmpfs 3,9G 0 3,9G 0% /sys/fs/cgroup /dev/sda1 511M 3,4M 508M 1% /boot/efi /dev/sdb1 59G 43G 14G 76% /cluster tmpfs 796M 0 796M 0% /run/user/1003 |
May 15, 2020, 10:48 |
Ok, thanks for this information. It indeed showed that the root partition (which is mounted as '/' in linux) is full. I would suggest the following: Code:
su cd / du -h --max-depth=1 the second line may not be necessary, but it takes you to the main root partition. The third line will show you the disk usage of each folder. If the /tmp folder is large, you can probably remove some files/folder there. Please do not touch other folders if you are not that familiar with linux. If you are unsure, please search online for what is in what folder. Hope this helps. Best of luck, Tom |
May 15, 2020, 10:58 |
#7 | |
Carlos
Rep Power: 6 |
cmoreno@clufa01:~$ su Password: su: Authentication failure cmoreno@clufa01:~$ cd / cmoreno@clufa01:/$ du -h --max-depth=1 16M ./bin du: cannot read directory './sys/fs/fuse/connections/41': Permission denied du: cannot read directory './sys/kernel/debug': Permission denied 0 ./sys 4.4G ./usr du: cannot read directory './cluster/lost+found': Permission denied du: cannot read directory './cluster/users/professors': Permission denied etc... |
May 15, 2020, 11:08 |
In that case you would need to contact the administrator. I guess he would be able to help you further.
Regards, Tom |
[snappyHexMesh] Error while running SnappyHex in parallel | mg.mithun | OpenFOAM Meshing & Mesh Conversion | 1 | February 10, 2016 13:13 |
Parallel running of 3D multiphase turbulence model (unknown problem!!) | MOHAMMAD67 | OpenFOAM Running, Solving & CFD | 7 | November 23, 2015 10:53 |
parallel running | student666 | OpenFOAM Running, Solving & CFD | 7 | May 21, 2014 14:55 |
Something weird encountered when running OpenFOAM in parallel on multiple nodes | xpqiu | OpenFOAM Running, Solving & CFD | 2 | May 2, 2013 04:59 |
Statically Compiling OpenFOAM Issues | herzfeldd | OpenFOAM Installation | 21 | January 6, 2009 09:38 |
