Difference between kEqn and one equation eddy viscosity model for LES simulations
Like Tree4Likes
  • 2 Post By clapointe
  • 1 Post By clapointe
Old   May 11, 2020, 10:08
Default Difference between kEqn and one equation eddy viscosity model for LES simulations
chandra shekhar pant
chandra shekhar pant is on a distinguished road
Dear FOAMERS,
I was reading a research article, and in that article it was mentioned that they used "one equation eddy viscosity model (OEEVM)", I checked the tutorials for this model but could not get some thing similar. I started searching some platform and found that "kEqn" is actually "one equation eddy viscosity model (OEEVM)". Is it true?
Any suggestion will be great help to me.
chandra shekhar pant is offline   Reply With Quote
Old   May 11, 2020, 16:38
clapointe is on a distinguished road
Yes, this is true to my knowledge -- just a product of naming change with OpenFOAM version. The kEqn model uses one equation for sgs turbulent kinetic energy transport and is a "one equation" model.
Eg. from OpenFOAM 2.4.x :
void oneEqEddy::updateSubGridScaleFields()
    muSgs_ = ck_*rho()*sqrt(k_)*delta();
And OpenFOAM 7
void kEqn<BasicTurbulenceModel>::correctNut()
    this->nut_ = Ck_*sqrt(k_)*this->delta();
Aside from general restructuring of turbulence model handling (i.e. muSgs vs nut) sgs viscosity is computed identically.
Caelan
clapointe is offline   Reply With Quote
Old   May 12, 2020, 01:19
Thanks a lot Caelan for your kind help and clarification. So every thing will be identical I guess in terms of BC for the variables etc? Thanks again
Old   May 12, 2020, 10:57
They likely will. Like I said, the turbulence modeling framework has changed a bit between versions (i.e. muSgs to nut) so required SGS variables will change a bit. You could figure out the differences by looking at tutorials from old and new openfoam releases.
Caelan
Old   May 17, 2020, 01:18
Thanks for your clarification, unfortunately, I have only OpenFOAM 1906 and don't have an access to other versions. But if I say that I am trying to replicate the results of the paper (which uses one equation eddy viscosity model) using the KEqn model then am I correct to say that I am using the same model as that been used by the paper? Does that make sense?
Old   May 17, 2020, 01:31
The code for older versions is always accessible, even if you don't use it -- just google for the repository. Yes it should be the same model.
Caelan
Old   May 17, 2020, 01:40
Thanks a lot Caelan for your wonderful help and support.
