Total heat release rate - variation not expected |
February 21, 2012, 09:52 |
Paulo Bufacchi
Rep Power: 15 |
Hi Foamers,
I ran into a variation in the total heat release rate when running two similar cases that were not expected to me. Let me explain what I did. I was running the case oppositeBurningPanels (fireFoam solver) with minor modifications as below: 1. the domain size in the Y direction was shortened from 4.2m to 2m; 2. the block resolution in the Y direction was lowered from 124 to 60; 3. the refinement block in the Y direction was shortened from 2.4m to 1m; 4. the panels height was shortened from 2.4m to 1m. Running the case as above, after time=3.00s I got a total heat release rate of -252 J/s. Then, for the second case I removed the right panel (in the original case there are two opposed panels). That's all I did. Running the second case with this single change, after time=3.00s I got a total heat release rate of -45 J/s. This value is 18% of the value in the first case. My expectation was the value to be 50% of the original one. Is there any reason for the total heat release rate to be so small in the second case? Thanks, Paulo |
Non-premixed combustion: local heat release rate | LB | FLUENT | 1 | April 28, 2021 22:11 |
Compiling OpenFOAM13 on AMD64 with OpenSUSE 101 | silent_missile | OpenFOAM Installation | 5 | August 10, 2007 07:31 |
heat tansfer rate and mass transfer rate | Ryan | FLUENT | 0 | June 29, 2007 11:13 |
heat release? | eric | Siemens | 1 | February 27, 2006 17:53 |
total pressure influence on heat transfer | fab | Main CFD Forum | 8 | May 19, 2005 09:24 |
