May 15, 2020, 09:35 |
odd results of kOmega SST and small yPlus
#1 | |||||||
AmiN
Rep Power: 11 |
Hi Cfd-Online!
I'm a newbie in OpenFOAM world and happen to submit weekly projects since last month! I' trying to simulate a very simple problem and geometry with kOmegaSST model in "simpleFoam" but the results are odd to me! The geometry as you can see in attachment is a semi-orifice form and the fluid is water at 25ºC and gotta simulate it for Re=30 and Re=3000! I dont use a fine mesh [Overall number of cells of each type : hexahedra: 40000] . With SST model i'm getting very small yPlus number for Re=3000 and Re=30 for example here are the results for Re=3000: Quote:
Both cases dont converge after 10000 interval which might be okay for Re=3000 but odd for Re=30, although after 8000 you dont see that much change in numbers. what do you thing about y+ and also k,Omega, nut behavior ? here are the conditions: U: Quote:
P: Quote:
Omega: Quote:
nut: Quote:
fvSolution: Quote:
May 16, 2020, 15:35 |
Klaus
Rep Power: 22 |
check this to better understand what you're trying to do: https://www.brighthubengineering.com...urbulent-flow/ Calculate the turbulence properties using e.g.: https://www.cfd-online.com/Tools/turbulence.php Dig a bit deeper into y+ ranges and mesh densities/properties suitable for your cases i.e. internal flow at your cases Re numbers. Calculate y+ wall distance using e.g.: https://www.cfd-online.com/Tools/yplus.php And create a mesh that meets the y+ wall distance requirement for your case Re = 3000 should be a turbulent case and kOmegaSST should work Re = 30 should be a laminar flow case so maybe switch off turbulence in the constant/turbulenceProperties file Code:
simulationType RAS; RAS { // Tested with kEpsilon, realizableKE, kOmega, kOmegaSST, v2f, // ShihQuadraticKE, LienCubicKE. RASModel kOmegaSST; turbulence on; // change this to off for laminar flow printCoeffs on; } |
bad heat transfer results with low y+ | me45 | OpenFOAM Running, Solving & CFD | 0 | April 29, 2020 11:56 |
RANS FX63-137 kOmega SST model | PierluigiRossi | SU2 | 2 | June 24, 2016 05:56 |
which yplus (SST) | sanchezz | CFX | 17 | January 11, 2010 04:45 |
how to make grid for "SST" like small Re method? | wayne | CFX | 0 | June 7, 2008 11:09 |
Small Yplus and k-epsilon | CFDworker | CFX | 3 | November 3, 2005 23:08 |
