MixingPlane tutorial crashing MRFSimpleFoam - Foam-extend |
May 27, 2020, 10:49 |
Rep Power: 6 |
Dear all,
I would like to get acquaintance with mixing planes in OpenFOAM so I installed foam-extend on my machine. First thing I did was trying to run a tutorial case and I chose the one in: tutorials/incompressible/MRFSimpleFoam/axialTurbine_mixingPlane The tutorial is set to run for 200 steps, but results look not reliable with a high time step continuity error on the last prescribed iteration. Furthermore, letting the simulation run for further steps it crashes at 226th step. Has someone noticed the same behavior? Are there any reliable tutorials about the use of mixing planes with the last foam-extend release (4.1)?? Thanks in advance |
[snappyHexMesh] Invalid Normals for source face to target face while making AMI? | Sorabh | OpenFOAM Meshing & Mesh Conversion | 1 | August 3, 2021 06:35 |
SimpleFoam cannot open include file | Marija | OpenFOAM Running, Solving & CFD | 1 | October 28, 2020 10:35 |
[mesh manipulation] RefineMesh Error and Foam warning | jiahui_93 | OpenFOAM Meshing & Mesh Conversion | 4 | March 3, 2018 11:32 |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 04:04 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
