June 7, 2020, 15:20 |
turbulentDFSEMInlet and boundaryFoam
Hüseyin Can Önel
Rep Power: 7 |
Hi Foamers,
I am trying to run a simulation with turbulentDFSEMInlet boundary condition. In the channel395DFSEM tutorial case, constant/boundaryData/inlet/0/L constant/boundaryData/inlet/0/R constant/boundaryData/inlet/0/U files are already available, which I see that are necessary for turbulentDFSEMInlet patch type. I am trying to find a way to obtain these files for my simulation. This reference says: The new surface format boundaryData, see $FOAM_SRC/sampling/sampledSurface/writers/boundaryData can be used to easily generate these files from previous simulations. If mapping data is unavailable, estimated field values can be specified directly, or generated e.g. by performing a boundaryFoam calculation to generate a fully developed 2-D inflow profile. So I am trying to run boundaryFoam for the of my domain. Are there any sample cases for such simulations? Or does anybody have experience with "using a previous simulation" to generate these files? Thanks in advance. |
September 14, 2020, 10:34 |
Francois Beaubert
I'm in the same boat.
Have a look at $FOAM_TUTORIALS/incompressible/boundaryFoam You will have the profiles in the postProcessing/graphs/{times} directories: epsilon.xy gammaDot.xy k.xy Rff.xy Rfw.xy Rww.xy Uf.xy uv.xy u.xy v.xy w.x |
