June 13, 2020, 09:27 |
twoPhaseEulerFoam particle diameter
Jagan Mohan
Rep Power: 6 |
Hello Team, I'm looking to compare twoPhaseEulerFoam (2PEF) and CFDEM setup via simulating minimum fluidization velocity. The particle diameter is 1.2 mm.
In phaseProperties, I'm declaring phases as (particles air). Here, I use diameterModel as constant and set d as 0.0012; for particle. 1. How do we estimate the alphaMax value? Also, for air too we use diameterModel as constant and set d as 1. 2. Why are we setting air diameter to 1? Thank you, Jagan Mohan. |
diametermodel, twophaseulerfoam |
Particle diameter calculation | hebe2u | CFX | 4 | February 21, 2019 04:43 |
twoPhaseEulerFoam - particle diameter distribution | Elm | OpenFOAM Pre-Processing | 2 | December 4, 2018 04:23 |
particles leave domain | Steffen595 | CFX | 9 | March 7, 2016 16:19 |
TwoPhaseEulerFoam high particle diameter problem OF2.1.1 | mwaqas | OpenFOAM Running, Solving & CFD | 0 | May 24, 2015 08:45 |
injection problem | Mark New | FLUENT | 0 | August 4, 2013 01:30 |
