Implemantation Temperature equation in interFoam
Old   June 14, 2020, 18:39
Default Implemantation Temperature equation in interFoam
Cláudio Corrêa
claudiocorrea is on a distinguished road
Dears,
I implemented temperature equation in interFoam on openFoam 7. After making changes in incompressibleTwoPhaseMixture and immiscibleIncompressibleTwoPhaseMixture and to compile I did the same with interFoam. Everything went well, but when to run one case to check if the newInterFoam it was working right, this error appear and the simulation blow up.
PIMPLE: Iteration 1
smoothSolver: Solving for alpha.water, Initial residual = 0.999931, Final residual = 3.74251e-17, No Iterations 1
Phase-1 volume fraction = 1.23783e-19 Min(alpha.water) = 0 Max(alpha.water) = 1
MULES: Correcting alpha.water
Phase-1 volume fraction = 1.23783e-19 Min(alpha.water) = -2.18953e-54 Max(alpha.water) = 1
smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 4.44102e-07, No Iterations 1
smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 4.27562e-07, No Iterations 1
smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 4.44386e-07, No Iterations 1
GAMG: Solving for p_rgh, Initial residual = 1, Final residual = 9.64132e-05, No Iterations 1000
time step continuity errors : sum local = 2.85405e-12, global = -4.21617e-14, cumulative = -4.21741e-14
smoothSolver: Solving for epsilon, Initial residual = 0.000141116, Final residual = 5.0585e-11, No Iterations 1
smoothSolver: Solving for k, Initial residual = 1, Final residual = 4.73213e-07, No Iterations 1
--> FOAM FATAL ERROR:
incompatible dimensions for operation
[T[1 -3 -1 1 0 0 0] ] - [T[1 -1 -3 0 0 0 0] ]
From function void Foam::checkMethod(const Foam::fvMatrix<Type>&, const Foam::fvMatrix<Type>&, const char*) [with Type = double]
in file /opt/openfoam7/src/finiteVolume/lnInclude/fvMatrix.C at line 1270.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::error::abort() at ??:?
#2 void Foam::checkMethod<double>(Foam::fvMatrix<double> const&, Foam::fvMatrix<double> const&, char const*) in "/home/claudio/OpenFOAM/claudio-7/platforms/linux64GccDPInt32Opt/bin/newInterFoam"
#3 Foam::tmp<Foam::fvMatrix<double> > Foam:perator-<double>(Foam::tmp<Foam::fvMatrix<double> > const&, Foam::tmp<Foam::fvMatrix<double> > const&) in "/home/claudio/OpenFOAM/claudio-7/platforms/linux64GccDPInt32Opt/bin/newInterFoam"
#4 ? in "/home/claudio/OpenFOAM/claudio-7/platforms/linux64GccDPInt32Opt/bin/newInterFoam"
#5 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#6 ? in "/home/claudio/OpenFOAM/claudio-7/platforms/linux64GccDPInt32Opt/bin/newInterFoam"
Aborted (core dumped)
Could someone tell me what´s going on?
claudiocorrea is offline   Reply With Quote
Old   June 17, 2020, 04:58
geth03 is on a distinguished road
the key error here is:
in your equation you have a dimension mismatch,
you try to substract kg*m*s^-3 from kg*m*s^-3*K.
can you show the equation with the dimensions please?
geth03 is offline   Reply With Quote
Old   June 17, 2020, 12:18
Cláudio Corrêa
Hi Geth03
Thank you for your support.
Attached follow the files TEqn.H, createFields, incompressibleTwoPhaseMixture and immiscibleIncompressibleTwoPhaseMixture.
Regards
File Type: h TEqn.H (304 Bytes, 20 views)
Old   June 18, 2020, 08:30
i checked your TEqn multiple times and i think the dimensions for each term is [T[1 -1 -3 0 0 0 0] ].
please note that in this case there is no temperature unit involved anymore,
so i don't know if the solution would then have any temperature unit out of thin air.
please correct me if i'm wrong.
Old   June 18, 2020, 13:21
Cláudio Corrêa
Thanks for analyzing my data. I wil confirm the data I entered in the interFoam and reply to you next week.
Old   July 16, 2020, 18:56
Cláudio Corrêa
I'm sorry for answering so late. You were right but I found my error. I didn't define kappa and Prandtl number in transportModel file. After this definition I got it to compile the new solver.
I haven't been able to simulate a case yet to check if solver is running fine.
Adding temperature equation to porousSimpleFoam David_010 OpenFOAM Programming & Development 9 February 14, 2018 01:22
Problem with Velocity Poisson Equation and Vector Potential Poisson Equation mykkujinu2201 Main CFD Forum 1 August 12, 2017 13:15
SimpleFoam and Temperature Equation Pat84 OpenFOAM Running, Solving & CFD 5 June 16, 2014 00:43
Adding temperature equation to twoPhaseEulerFoam nikhil5490 OpenFOAM Programming & Development 0 April 30, 2014 13:28
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 01:27
