Implemantation Temperature equation in interFoam |
June 14, 2020, 18:39 |
Cláudio Corrêa
Rep Power: 9 |
Dears,
I implemented temperature equation in interFoam on openFoam 7. After making changes in incompressibleTwoPhaseMixture and immiscibleIncompressibleTwoPhaseMixture and to compile I did the same with interFoam. Everything went well, but when to run one case to check if the newInterFoam it was working right, this error appear and the simulation blow up. PIMPLE: Iteration 1 smoothSolver: Solving for alpha.water, Initial residual = 0.999931, Final residual = 3.74251e-17, No Iterations 1 Phase-1 volume fraction = 1.23783e-19 Min(alpha.water) = 0 Max(alpha.water) = 1 MULES: Correcting alpha.water MULES: Correcting alpha.water Phase-1 volume fraction = 1.23783e-19 Min(alpha.water) = -2.18953e-54 Max(alpha.water) = 1 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 4.44102e-07, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 4.27562e-07, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 4.44386e-07, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 1, Final residual = 9.64132e-05, No Iterations 1000 time step continuity errors : sum local = 2.85405e-12, global = -4.21617e-14, cumulative = -4.21741e-14 smoothSolver: Solving for epsilon, Initial residual = 0.000141116, Final residual = 5.0585e-11, No Iterations 1 smoothSolver: Solving for k, Initial residual = 1, Final residual = 4.73213e-07, No Iterations 1 --> FOAM FATAL ERROR: incompatible dimensions for operation [T[1 -3 -1 1 0 0 0] ] - [T[1 -1 -3 0 0 0 0] ] From function void Foam::checkMethod(const Foam::fvMatrix<Type>&, const Foam::fvMatrix<Type>&, const char*) [with Type = double] in file /opt/openfoam7/src/finiteVolume/lnInclude/fvMatrix.C at line 1270. FOAM aborting #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 void Foam::checkMethod<double>(Foam::fvMatrix<double> const&, Foam::fvMatrix<double> const&, char const*) in "/home/claudio/OpenFOAM/claudio-7/platforms/linux64GccDPInt32Opt/bin/newInterFoam" #3 Foam::tmp<Foam::fvMatrix<double> > Foam:perator-<double>(Foam::tmp<Foam::fvMatrix<double> > const&, Foam::tmp<Foam::fvMatrix<double> > const&) in "/home/claudio/OpenFOAM/claudio-7/platforms/linux64GccDPInt32Opt/bin/newInterFoam" #4 ? in "/home/claudio/OpenFOAM/claudio-7/platforms/linux64GccDPInt32Opt/bin/newInterFoam" #5 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #6 ? in "/home/claudio/OpenFOAM/claudio-7/platforms/linux64GccDPInt32Opt/bin/newInterFoam" Aborted (core dumped) Could someone tell me what´s going on? |
June 17, 2020, 04:58 |
Rep Power: 8 |
the key error here is:
--> FOAM FATAL ERROR: incompatible dimensions for operation [T[1 -3 -1 1 0 0 0] ] - [T[1 -1 -3 0 0 0 0] ] in your equation you have a dimension mismatch, you try to substract kg*m*s^-3 from kg*m*s^-3*K. can you show the equation with the dimensions please? |
June 17, 2020, 12:18 |
#3 | |
Cláudio Corrêa
Rep Power: 9 |
Thank you for your support. Attached follow the files TEqn.H, createFields, incompressibleTwoPhaseMixture and immiscibleIncompressibleTwoPhaseMixture. Regards |
June 18, 2020, 08:30 |
Rep Power: 8 |
i checked your TEqn multiple times and i think the dimensions for each term is [T[1 -1 -3 0 0 0 0] ].
please note that in this case there is no temperature unit involved anymore, so i don't know if the solution would then have any temperature unit out of thin air. please correct me if i'm wrong. |
June 18, 2020, 13:21 |
#5 | |
Cláudio Corrêa
Rep Power: 9 |
July 16, 2020, 18:56 |
#6 | |
Cláudio Corrêa
Rep Power: 9 |
I haven't been able to simulate a case yet to check if solver is running fine. |
Adding temperature equation to porousSimpleFoam | David_010 | OpenFOAM Programming & Development | 9 | February 14, 2018 01:22 |
Problem with Velocity Poisson Equation and Vector Potential Poisson Equation | mykkujinu2201 | Main CFD Forum | 1 | August 12, 2017 13:15 |
SimpleFoam and Temperature Equation | Pat84 | OpenFOAM Running, Solving & CFD | 5 | June 16, 2014 00:43 |
Adding temperature equation to twoPhaseEulerFoam | nikhil5490 | OpenFOAM Programming & Development | 0 | April 30, 2014 13:28 |
is internalField(U) equivalent to zeroGradient? | immortality | OpenFOAM Running, Solving & CFD | 7 | March 29, 2013 01:27 |
