Unphysical temperature drop when using dynamic mesh |
June 18, 2020, 13:07 |
peyman havaej
Rep Power: 10 |
Dear All
I have recently added an Energy equation to a compressible flow solver developed by myself. It seems that the energy equation is solved correctly on the static mesh; it presents a logical and physical solution. However, when there is a mesh motion, an unreasonable temperature drop is observed in the fluid domain. I have tried to debug and fix this issue., therefore, considering the following simplified energy equation: Code:
fvm::ddt(T) ==fvm::laplacian(alphaThermal,T) I have found the unreasonable temperature drop or conservativeness problem is due to the transient term (fvm::ddt(T)). I have searched for a solution, but I still do not know how I can deal with this problem. I will appreciate it if anyone has any idea or suggestion about this problem. Best regards, Peyman dynamicMeshDict: Code:
dynamicFvMesh dynamicMotionSolverFvMesh; solver velocityLaplacian; diffusivity quadratic inverseDistance 1(interface_fluid); Code:
internalField uniform (0 0 0); boundaryField { interface_fluid { type fixedValue; value uniform (0 0.04 0); } inlet { type slip; value uniform (0 0 0); } outlet { type slip; value uniform (0 0 0); } bottumWalls { type fixedValue; value uniform (0 0 0); } topWalls { type fixedValue; value uniform (0 0 0); } frontAndBack { type empty; } } T Code:
internalField uniform 353.15; boundaryField { inlet { type fixedValue; value $internalField; } outlet { type fixedValue; value $internalField; } bottumWalls { type fixedValue; value $internalField; } topWalls { type fixedValue; value $internalField; } interface_fluid { type fixedValue; value uniform 353.15; } frontAndBack { type empty; } } |
conservative variables, dynamic mesh, energy equation, numerical error, openfoam |
Dynamic Mesh | kennyboy | FLUENT | 1 | February 23, 2019 01:52 |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
Local mesh refinement definition in a DEFORMING dynamic mesh zone using Dynamic Mesh | Emanuele88 | FLUENT | 0 | February 9, 2016 11:39 |
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 17:00 |
dynamic mesh for drop interface | IndrajitW | FLUENT | 0 | March 30, 2013 08:03 |
