constantAlphaContactAngle and cyclicAMI together |
July 22, 2020, 13:33 |
Hello Sir/Ma'am,
I am thinking of using cyclicAMI with constantAlphaContactAngle BC together in alpha.water file, is it possible? Or should I use cyclicACMI? I know how to set it up for cyclicAMI: essentially, need to have 'cyclicAMI' defined in 'boundary' file, then defined it as translational or rotational as CFD user's choice, then apply specific parameters as per the translational or rotational definition in 'boundary' file inside polymesh. But, Now, in 0 folder, inside 'alpha.fluid','U','p_rgh' files, mention 'cyclicAMI' type for cyclicAMI case, thus my confusion is that is it possible to stack two types together? that is, can apply, type 'cyclicAMI', and type 'constantAlphaContactAngle' for same patch in alpha.fluid file? |
alpha.water, constantalphacontactangle, cyclic ami, interfoam |
Using createPatch and cyclicAMI in FOAM Extend to create periodicbox | manuc | OpenFOAM Running, Solving & CFD | 1 | April 12, 2022 11:36 |
Getting started with CyclicAMI | Algebraist | OpenFOAM | 4 | February 11, 2019 01:39 |
cyclicAMI - kOmegaSST - divergence issue | cyln | OpenFOAM Running, Solving & CFD | 1 | October 5, 2018 10:06 |
cyclic / cyclicAMI boundary conditon - ICEM Mesh | cyln | OpenFOAM Running, Solving & CFD | 0 | November 7, 2017 15:26 |
Boundary Layer strange result | fernexda | OpenFOAM Running, Solving & CFD | 14 | January 15, 2015 07:21 |
