obtaining significantly different Flow profiles after only changing Mesh size
Old   June 30, 2020, 12:06
Default obtaining significantly different Flow profiles after only changing Mesh size
berat
beratcagan is on a distinguished road
so i am new to OpenFOAM and simulation in general and i am currently trying to simulate a two dimentional pipe flow. I managed to obtain a satisfiying result/flow profile in my simulation.
Now I am looking to making the simualtion bigger by simply changing the value form the "converttoMeter" command in the BlockMesh file. When i do so i am getting a completly unrealistic flow profile, even though every other part of the Simualtion is exactly the same. I allready tried increasing/decreacing the velocity at the input patch, this didnt change anything though.
BlockMesh of the working Simulation:
convertToMeters 0.000001;
vertices
(0 0 0)
(35000 0 0)
(35000 3500 0)
(0 3500 0)
(0 0 65)
(35000 0 65)
(35000 3500 65)
(0 3500 65)
blockMesh of the faulty simulation
convertToMeters 1;
vertices
(0 0 0)
(35000 0 0)
(35000 3500 0)
(0 3500 0)
(0 0 65)
(35000 0 65)
(35000 3500 65)
(0 3500 65)
as i already mentioned the rest of the simulation is exactly the same, despite me tryed to change up the velocity which didnt change anything though.
now i am curious what i am doing wrong. i would appreate the sightest hints which would help me solve my problem.
beratcagan is offline   Reply With Quote
Old   June 30, 2020, 15:07
Troy Snyder
tas38 is on a distinguished road
In your faulty simulation, the length scales are increased dramatically. Correspondingly, your Reynolds number has increased significantly given the same U and fluid properties rho and mu.
Is the solution converging for the high-Re case?
Is the flow modeled as laminar or turbulent?
tas38 is offline   Reply With Quote
Old   July 1, 2020, 11:28
berat
thank you, I never concidered the reynolds number. But i calculated the Reynolds number by hand and get 2.17. so i should still have laminar flow.
to be hornest i didnt know what convergence in fluid dynamics are up till now, after looking it up. i can tell you that i didn't implement anything to help with convergence. so my simulation probably doesn't converge for high-Re cases.
Do i have any other options of assuring convergence besides implementing relaxationFactors?
i am using the piso solver and i have the simulationType set to laminar in the turbulenceProperties file.
Old   July 1, 2020, 12:14
Troy Snyder
Using incompressible piso in openfoam, the only fluid property to specify is kinematic viscosity. What value did you prescibe for this and the inlet velocity for the faulty mesh case? I
Old   July 1, 2020, 12:22
berat
transportModel  Newtonian;
nu              nu [ 0 2 -1 0 0 0 0 ] 1;
CrossPowerLawCoeffs
    nu0             nu0 [ 0 2 -1 0 0 0 0 ] 1;
    nuInf           nuInf [ 0 2 -1 0 0 0 0 ] 1;
    m               m [ 0 0 1 0 0 0 0 ] 1;
    n               n [ 0 0 0 0 0 0 0 ] 1;
BirdCarreauCoeffs
    k               k [ 0 0 1 0 0 0 0 ] 0;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    inlet
        type            fixedValue;
	value		uniform (0.62e-3 0 0);
    outlet
        type            zeroGradient;
    walls
        type		noSlip;
but i should mention here that i am am also using this line of code here. so the units are in micro. e.g μg, μm etc.
DimensionedConstants
    unitSet             micro;
microCoeffs
universal
c c [ 0 1 -1 0 0 0 0 ] 2.99792e+8; // speed of light in vacuum (µm/µs)
G G [ -1 3 -2 0 0 0 0 ] 6.67429e-20; // gravitational constant (µm^3/(pgµs^2))
h h [ 1 2 -1 0 0 0 0 ] 6.62607e-13; // Planck's constant (pgµm^2/µs)
electromagnetic
e e [ 0 0 1 0 0 1 0 ] 1.602176634e-4; // elementary charge (pC)
atomic
me me [ 1 0 0 0 0 0 0 ] 9.10938e-16; // electron mass (pg)
mp mp [ 1 0 0 0 0 0 0 ] 1.67262e-12; // proton mass (pg)
physicoChemical
mu mu [ 1 0 0 0 0 0 0 ] 1.66054e-12; // atomic mass unit (pg)
k k [ 1 2 -2 -1 0 0 0 ] 1.38065e-8; // Boltzman constant (pgµm^2/µs^2K)
standard
//- Standard pressure [pg/µmµs^2 ]
Pstd Pstd [ 1 -1 -2 0 0 0 0 ] 1e2; // 1 pg/µmµs^2
//- Standard temperature [degK]
Tstd Tstd [ 0 0 0 1 0 0 0 ] 298.15; // should be same as in SI unit system
Old   July 1, 2020, 12:28
berat
kinematic viscosity is 1
velocity is (0.62e-3 0 0)
i should also metion, that i have been using the "unitSet micro" command which is supposed to change the units into micro. so its not kg,m etc anymore, but rather μg, μm etc.
foam-extend-4.1 release hjasak OpenFOAM Announcements from Other Sources 19 July 16, 2021 05:02
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
mass flow rate and size of mesh zandi CFX 9 February 21, 2010 04:31
Changing mesh size for independency test az_f ANSYS Meshing & Geometry 1 August 27, 2009 13:55
