Multiple solids
Old   July 1, 2020, 10:45
Default Multiple solids
hamid
mrbenson is on a distinguished road
Hi everybody,
I try to simulate a very basic steadystate solid heat transfer problem of two solids (cube) joined by a common surface.
1 - I created the mesh with gmsh which contains two volumes and i converted the msh file with gmshToFoam, so that it seems to geneate everything under constant/polyMesh
2 - I created two files :
Constant\solid1\solidThermophysicalProperties
Constant\solid2\solidThermophysicalProperties
they contains a constSolidThermoCoeffs section with a K value.
3 - The two solids have different thermal conducitivties, as far as i understand laplacianFoam solver does not take in charge different values of conductivity, so i must use chtMultiRegionSimpleFoam solver. This solver indicates i need to have polymesh defined in each folder constant/solid1/2. I do not understand something cause constant/polymesh contains everything.
4 - If i defined two solids in Constant/regionProperties i get "fluid not found in table"
Any help please...
mrbenson is offline   Reply With Quote
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! divergence OpenFOAM Meshing & Mesh Conversion 0 January 23, 2019 04:17
[OpenFOAM.org] Install openFOAM 3.0.1 in Ubuntu 16.04 LTS from Deb packs Pier84 OpenFOAM Installation 4 June 18, 2016 16:22
[ICEM] part from ICEM to CFX multiple solids Steffen595 ANSYS Meshing & Geometry 2 May 20, 2016 18:48
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 12:21
