How to move rotorDisk tutorial?
Old   July 2, 2020, 14:07
Question How to move rotorDisk tutorial?
DanFO is on a distinguished road
Hello everyone,
My question is simple: How to impose motion to the rotor disk?
I refer to the rotor disk in the tutorial case "rotorDisk" found in: $FOAM_TUTORIALS/incompressible/simpleFoam/rotorDisk.
Or, if you prefer online: https://develop.openfoam.com/Develop...Foam/rotorDisk
I want to impose an oscillatory motion (sinusoidal) to the disk and analyze its transient response. I think the first step is to change the default solver "simpleFoam" (steady-state solver) to "pimpleFoam" (transient solver). And I managed to do this. Second step is to impose the motion, and I know how to do it for a Boundary Field using dynamicMeshDict and pointDisplacement (as we do for an oscillating cylinder). But the problem is that the rotor disk is not a boundary, it is a region of cells inside the domain and I didn't understand clearly how it is defined.
So, I would appreciate if someone could explain how the disk region is defined and how to impose an oscillatory motion to it.
(I'm using OpenFOAM 7, and I'm quite new to the software)
Thank you!
DanFO is offline   Reply With Quote
Old   July 2, 2020, 20:58
Ardalan
Ardali is on a distinguished road
This question needs a broad range of answer.
For a start check
$FOAM_TUTORIALS/incompressible/simpleFoam/mixerVessel2D
$FOAM_TUTORIALS//incompressible/pimpleFoam/RAS/propeller
search AMI functionality, you will find lots of useful links.
GGI is another functionality which is available only on FOAM-extended versions.
These two are applied on interfaces for a rotor-stator interaction.
MRF functionality is a steady solution for rotor-stator solution.
Good luck
Ardalan
Ardali is offline   Reply With Quote
Old   July 3, 2020, 11:24
Hello Ardalan,
I see that your suggestions are great for solving rotational mesh problems. But I don't want to rotate the disk. To better explain my problem: I want to model a floating offshore wind turbine moving up and down with waves. So, to simplify the problem, I want to simulate an actuator disk moving up and down. The whole mesh could move around the disk as for ALE (Arbitrary Lagrangian Eulerian) methods of dynamic mesh. So, how to apply vertical oscillatory motion to the disk?
Thank you for your attention
Old   July 3, 2020, 12:46
Ardalan
OK, it seems you want to replicate the effect of tidal wave on your turbine.
Please check
$FOAM_TUTORIALS/incomressible/pimpleFoam/laminar/movingCone
Please also check
$FOAM_TUTORIALS/incomressible/pimpleFoam/RAS/wingMotion
They have different dynamicMeshDict in constant folder.
Ardalan
Old   July 6, 2020, 14:42
Question
Hi Ardalan,
Both tutorial cases impose motion to a boundary.
In the "movingCone" case, it is applied a velocity on the "movingWall" boundary, as we can see on file "0/pointMotionUx":
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform 0;
boundaryField
    movingWall
        type            uniformFixedValue;
        uniformValue    constant 1;
In the "wingMotion" case, a displacement is calculated on the "wing" boundary, as we can see on "wingMotion2D_pimpleFoam/pointDisplacement":
dimensions      [0 1 0 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    wing
        type            calculated;
        value           uniform (0 0 0);
But in the "rotorDisk" case, I think the disk which I want to apply a displacement is not a boundary. It is the objects defined on "constant/triSurface": "fixed.obj", and "rotatingZone.obj".
As we can see, the boundary conditions for the "rotorDisk" case are, for example "0/U":
Uinlet          (0 1 0);
internalField   uniform $Uinlet;
boundaryField
    inlet
        type            fixedValue;
        value           uniform $Uinlet;
    outlet
        type            pressureInletOutletVelocity;
    "slip.*"
        type            slip;
    #includeEtc "caseDicts/setConstraintTypes"
So, how to create a "pointDisplacement" file that imposes a motion to the disk (fixed.obj and rotatingZone.obj), which is not a boundary field?
Thanks
Old   June 2, 2021, 08:24
Question
4lix is on a distinguished road
Hi DanFO,
Did you find a way to move your actuator disk up and down ?
I am very interesting to hear about your solution.
I am working on ship self propulsion and I want to connect the actuator disk to the ship so that they can move together.
Thanks in advance for your time and consideration!
Best regards,
Alix
4lix is offline   Reply With Quote
Old   November 8, 2021, 05:41
Talay
Talayal is on a distinguished road
Hi Alix,
Were you able to do it? I am looking for the answer to the same problem..
Originally Posted by 4lix View Post
Hi DanFO,
Best regards,
Alix
Talayal is offline   Reply With Quote
Old   November 15, 2021, 08:51
Post
Hi Talay,
I was not able to do it.
Here is an answer from Herpes to the same question that may help you: boatAndPropeller tutorial with actuator disk
Let me know if you find something else!
Best regards,
Alix
Old   November 16, 2021, 00:40
Talay
Hi Alix,
Thanks for the reply. Actually, in the mean time I was able to capture the motion of the disk with a trick. I couldn't figure out how to move the disk so I increased the innerdistance parameter for the hull in dynamicmeshdict. Since the disk is close to the hull (closer than the innerdistance value), it is moving with it. You can find the description of the parameter below;
https://openfoamwiki.net/index.php/P...Outer_Distance
actuator disk, oscillating body, rotordisk
tutorial files KITetima FLUENT 8 November 23, 2019 16:05
AMI - Propeller Tutorial diverging kingmaker OpenFOAM Running, Solving & CFD 2 November 4, 2016 02:57
Tutorial For Workbench CFX Remesh ashtonJ CFX 2 April 26, 2014 21:19
Fluent Tutorial Guide Ch. 17: Non-Premixed Combust, THTR MAE7509 FLUENT 0 January 22, 2014 20:59
STAR-CD Tutorial shekhar aryal STAR-CD 4 March 22, 2010 03:25
