Updating a boundary condition from the solver |
May 30, 2008, 03:56 |
I'd like to bother you all wit
Juho Peltola
Rep Power: 17 |
I'd like to bother you all with a question again, sorry about it.
I've tried to update a boundary condition on each timestep based on values of the solution of the earlier steps. The field I want to modify is a scalar and the boundary is defined as a uniform fixedValue. I've tried to update it by including lines: variable.boundaryField()[patchI] = newValue; variable.correctBoundaryConditions(); in to the time loop. newValue is a scalar which is calculated on each timestep. As many you must have noticed by now, it doesn't work. The values on the boundary patch don't change, even if the newValue changes. What is the correct way to do this? |
June 3, 2008, 05:28 |
Try
Eugene de Villiers
Rep Power: 21 |
Try
variable.boundaryField()[patchI] == newValue; The important bit is the double "==". |
June 3, 2008, 06:00 |
Thank you!! Works perfectly!
Juho Peltola
Rep Power: 17 |
I had given up on doing it in the solver was writing a boundary condition to do it. |
June 3, 2008, 06:35 |
Well doing it as a boundary co
Eugene de Villiers
Rep Power: 21 |
Well doing it as a boundary condition is probably the "best" way of going about things.
Performing the assignment in the solver is a lot quicker to code though! |
September 19, 2008, 03:19 |
Hi
"I've tried to update it
Tian
Rep Power: 17 |
Hi
"I've tried to update it by including lines:" Can you give me an excample for the time loop? I also want to update the boundary condition for U after every iteration. I want use the bouyantSimpleFoam. Thanks a lot Bye Thomas
BIM HVACTool, The Green Building Simulation Tool for OpenFOAM, Energy Plus and Radiance. |
November 19, 2008, 07:29 |
Hi Juho and Eugene
I want t
Niranjan Ghaisas
Rep Power: 17 |
Hi Juho and Eugene
I want to implement a boundary condition that reads values from the previous time step and sets the gradient of another variable at the boundaries. More specifically, I am trying to set the pressure gradient at the boundaries based on the temperature calculated in the previous time step. dp/dz = g*beta*(T-Tref) Could you giveme some pointers for doing that? Thanks Niranjan |
November 20, 2008, 05:05 |
Hi Adam
Am I glad that you
Niranjan Ghaisas
Rep Power: 17 |
Hi Adam
Am I glad that you jumped in! Thanks for these detailed instructions. Will try them out. Thanks a lot. Niranjan |
March 18, 2011, 09:42 |
isabel
Rep Power: 17 |
Hello everybody,
I want to update a boundary condition called “ABAJO” on each timestep based on the values of the solution of the previous timestep. Particularty, I want to correct the variable T2=110*gamma. I have written this code: label inletPatchID = mesh.boundaryMesh().findPatchID("ABAJO"); fvPatchScalarField& condition = T2.boundaryField()[inletPatchID]; forAll(condition, patchI) { T2.boundaryField()[patchI] = 110*gamma.boundaryField()[patchI]; } T2.correctBoundaryConditions(); The solver compiles Ok, but when I run the tutorial I have the following error: #0 Foam::error:rintStack(Foam::Ostream&) in "/home/isabel/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigSegv::sigSegvHandler(int) in "/home/isabel/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: [0xb7766400] #3 main in "/home/isabel/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/17marzo5" #4 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #5 _start at /build/buildd/glibc-2.9/csu/../sysdeps/i386/elf/start.S:122 Segmentation error |
June 14, 2021, 12:55 |
#9 |
pardoa
Rep Power: 8 |
Hello everyone,
This is an old post but maybe any of you can help me to solve the issue that I am currently facing. I wish to turn into zero the values calculated by interFoam at the boundaries if alpha1 (water fraction) is lower than 0.1. I have managed to achieve this at the cells, but somehow I cannot make it at the boundaries. Since OpenFOAM treats the internalFields and boundaryFields separately, I need also to convert the values of the cells and boundary faces whose alpha1 value is smaller than 0.1 into 0. Everything works for the internalFields: Code:
forAll(alpha1,i) { if (alpha1[i] < 0.1) { dSur[i] = 0.0; piezoSur[i] = 0.0; hSur[i] = 0.0; } else { dSur[i] = p[i]/(rho[i]*mag(gSur[i])); piezoSur[i] = dSur[i] + (meshSurface.C()[i].component(vector::Z)+zRef[i]); hSur[i] = ((0.5*magSqr(U[i]))/mag(gSur[i])) + dSur[i] + (meshSurface.C()[i].component(vector::Z)+zRef[i]); } } Code:
forAll (meshSurface.boundaryMesh(),patchID) { forAll (meshSurface.boundaryMesh()[patchID],i) { dSur.boundaryField()[patchID][i] = p.boundaryField()[patchID][i]/(rho.boundaryField()[patchID][i]*mag(gSur[patchID][i])); } } PHP Code:
Any help will be greatly welcomed! Thanks! |
Boundary condition error depending on location of solver execution | kjmaki | OpenFOAM Running, Solving & CFD | 0 | June 18, 2008 15:04 |
Boundary condition of the third kind or Danckwertz boundary condition | plage | OpenFOAM Running, Solving & CFD | 4 | October 3, 2006 12:21 |
How to setup boundary condition with couple solver | JINHUI | FLUENT | 0 | September 8, 2006 17:07 |
boundary condition for high order Possion solver | jen | Main CFD Forum | 0 | November 16, 2005 19:04 |
boundary condition for high order possion solver *NM* | jen | Main CFD Forum | 0 | November 16, 2005 19:02 |
