Chtmultiregionfoam
Old   June 12, 2015, 12:54
Default Chtmultiregionfoam
Peng Liang
tjliang is on a distinguished road
Hello Foamers,
I am intending to simulate arc discharge in a laval nozzle, but using chtmultiregionfoam i always can't get a reseanable results , the time step always turns out to be extremly small and pressure and velocity distribution also unreasonable.
Can chtSolver really simulate transsonic and supersonic problems? I see from .C File that it'a combination of bouyantFoam and HeatconductionFoam.
Thanks in advance.
Peng
tjliang is offline   Reply With Quote
Old   June 12, 2015, 14:29
N/A
kamakura117 is on a distinguished road
chtMultiRegionFoam is not ideally suited for trans-sonic, supersonic cases. You will need to combine sonicFoam with the multiRegion capabilities of chtMultiRegionFoam.
kamakura117 is offline   Reply With Quote
Old   September 6, 2021, 07:22
Joao Coelho
jcoelho5 is on a distinguished road
Was anyone able to "merge" chtMultiRegionFoam with any solver for high speed flow? (rhoCentralFoam or sonicFoam).
Thanks.
jcoelho5 is offline   Reply With Quote
Error in thermophysical properties (chtMultiRegionFoam) mukut OpenFOAM Pre-Processing 28 November 23, 2021 06:34
chtMultiRegionFoam connection between solid and fluid region of heat exchanger ahab OpenFOAM 1 December 18, 2019 00:37
chtmultiregionFoam error oilsok OpenFOAM Running, Solving & CFD 1 June 12, 2014 11:19
FOAM FATAL IO ERROR for chtMultiRegionFoam xiaoyoyo OpenFOAM Running, Solving & CFD 0 May 8, 2012 16:49
Embed explicitSetValue in chtMultiRegionFoam samiam1000 OpenFOAM 2 April 18, 2012 05:14
