rushton turbine + MRF impeller tip higher speed than physically possible?
Old   July 28, 2022, 09:02
Default rushton turbine + MRF impeller tip higher speed than physically possible?
geth03 is on a distinguished road
hi all,
i am currently simulating
- a 6 blade rushton impeller with 4 baffles in a tank/mixing vessel
with following specs:
- rotor/stator: MRF -> 14 rps -> Re=40.000 turbulent
- U_tip = PI*D*N = 2.24 m/s
however, when i normalize the tangential velocity, i.e. U_tangential/U_tip, the max value i get is larger than 1 for the impeller tip (see attached file).
the results i saw from publications don't have such values, does it even make sense that the impeller tip is faster than the theoretical value?
thanks for any tips and hints
geth03 is offline   Reply With Quote
Old   May 27, 2023, 08:44
FOAMraj
BIRAJ is on a distinguished road
Hi geth, how did you calculate the tip speed, and radial and tangential velocity of the impeller? I am also in the same boat rn. TIA
BIRAJ is offline   Reply With Quote
Geometry of Tank and Rushton Turbine in Gambit jawidnaik ANSYS Meshing & Geometry 1 February 4, 2015 07:28
Sliding mesh vs MRF in axial turbine simulation Vito FLUENT 3 December 21, 2011 04:57
meshing a rushton turbine Randheer Yadav FLUENT 5 September 24, 2010 03:12
Tip speed, RPM, Power, Wind Speed relationships nabilzhafri Main CFD Forum 0 July 22, 2010 11:28
[ICEM] Turbine blade with filleting and tip clearance Pursuor ANSYS Meshing & Geometry 4 July 7, 2010 13:56
