outletStabilised scheme not specified
Old   September 22, 2020, 05:58
Default outletStabilised scheme not specified
Jin Zhang
sjlouie91 is on a distinguished road
Dear Foamers,
I am now trying to use outletStabilised scheme in my LES case. However, when I set the scheme as
div(phi, U) Gauss outletStabilised
it shows that discretisation scheme not specified. But this scheme is among the valid schemes.
So I don't know how I can deal with this problem. Has anyone used this scheme before?
sjlouie91 is offline   Reply With Quote
Old   September 22, 2020, 19:35
clapointe is on a distinguished road
If I remember correctly, it "modifies" a scheme -- so you would need to specify, for example, Gauss outletStabilised linear. However, if stabilization is required at the outlet it might be worth double checking the bc's before relying on the outletStabilised to (hopefully) do it for you.
Caelan
clapointe is offline   Reply With Quote
Old   September 23, 2020, 05:18
Jin Zhang
Caelan
Thank you so much.
Actually before I am trying to use outletStabilised scheme, I used linear scheme. As my case is running in a truncated domain, the outlet is 2 chord length away from the airfoil. So I used advective boundary condition for velocity and pressure, and ZG for nut. However, it went well for about 8-9 flow-through time, and after that nut begins to oscillate from the wake and finally affected the pressure side of the airfoil. But there is no reflection flow as I set advective BC for velocity.
Do you have any idea about how to solve this problem?
Old   September 23, 2020, 09:50
Short of extending the domain to make the outlet further from the airfoil, retaining stability will likely be tricky. There are a number of numerical games you could start playing, but whether those are warranted (over changing the mesh) is another matter...
Caelan
fvschemes, les, outletstabilised
how to understand high resolution scheme and high order scheme iilw1314 Main CFD Forum 7 April 12, 2022 12:29
Error: Out of scheme heap space SSG_NJ FLUENT 2 July 24, 2021 06:31
Crank Nicolson scheme implemented wrong? rajibroy OpenFOAM Programming & Development 10 May 5, 2020 09:57
2nd order upwind scheme (Fluent and CFX) Far FLUENT 0 May 22, 2011 01:50
extrapolation in MUSCL scheme Chandra Main CFD Forum 6 February 14, 2007 11:21
