Heat flux through a baffle in hyper-sonic regime. Help! |
June 24, 2020, 11:55 |
Hi everyone I'm having some troubles figuring out which thermal boundary conditions to apply over a baffle to calculate a sensible heat flux through it in hypersonic regime. I am using rhoCentralFoam as solver and I'm trying with these settings
T { type compressible::thermalBaffle1D<hConstSolidThermoPhy sics>} Is it correct to use these boundary conditions in OpenFOAM in case of hypersonic flow? Thanks in advance |
October 3, 2020, 12:53 |
Febriyan Prayoga
Rep Power: 10 |
Hello Valerio, I am interested in your case. did you solved your problem yet?
I am working with rhoCentralFoam too. I am using kw-SST turbulence model on rCF with adiabatic wall. I want to know the amount of wall heat flux and change the wall B.C but I don't know which B.C i should change first. I will be very happy if you could share some clues. Last edited by febriyan91; October 3, 2020 at 12:59. Reason: less description |
baffles, heat boundary condition, hypersonic flow, rhocentralfoam, temperature |
Total heat transf. rate vs Total surface heat flux | Renato Sousa | FLUENT | 1 | April 14, 2020 03:27 |
Udf for moving heat flux in 2D cylindrical geometry | devia21 | Fluent UDF and Scheme Programming | 0 | April 20, 2015 00:27 |
Monitor Heat Flux in CFD-Pre | cltormar | CFX | 5 | November 20, 2014 11:45 |
Variable name for heat flux | peterle | CFX | 4 | February 13, 2014 02:21 |
Enforce bounds error with heat loss boundary condition at solid walls | Chander | CFX | 2 | May 1, 2012 20:11 |
