VOF method and Marangoni flows
Like Tree1Likes
Old   February 26, 2010, 05:02
Default VOF method and Marangoni flows
Frank
fmuldoo is on a distinguished road
I was wondering if it is possible to model temperature dependent surface tension (Marangoni) effects in OpenFOAM while using the VOF method.
Cheers,
Frank
fmuldoo is offline   Reply With Quote
Old   February 27, 2010, 13:39
Eelco Gehring
feijooos is on a distinguished road
Frank,
No, I don't OF has that capability yet. But you can always program it yourself.
feijooos is offline   Reply With Quote
Old   September 16, 2015, 16:09
Default Did anyone find any update on the VOF+Marangoni
Lotte
jackslot is on a distinguished road
Hi I am facing the same problem. So I am wondering if anyone has update on this issue.
Thanks,
Lotte
jackslot is offline   Reply With Quote
Old   February 22, 2017, 15:30
Kalpana Hanthanan Arachchilage
kal1943335 is on a distinguished road
Dear all,
I have been working on implementation tangential surface tension component to simulate marngoni flows due to temperature differences. I'm having a hard time validating my results with the existing analytical work.
Have you guys managed to figure out a way to simulate this.
Thanking you in advance.
Kalpana.
kal1943335 is offline   Reply With Quote
Old   November 22, 2018, 10:15
cyw
Yuanwei Cao
cyw is on a distinguished road
Originally Posted by kal1943335 View Post
Dear all,
Kalpana.
have you implemented tangential surface tension component?
cyw is offline   Reply With Quote
Old   November 26, 2018, 18:15
Yes, I did. the only problem is the validation. I compared it with the analytical solution, but had a hard time with spurious currents (analytical solution is available for small capillary numbers)
kalpana
Old   November 27, 2018, 03:55
cyw
Yuanwei Cao
kalpana
Thank you for you reply. Yes, spurious current is a big problem for interFoam. Here is a discussion on it In attempt to decrease spurious currents in VOF.
Can I ask you how did you implement the equations in the attached file? My email is yuanwei.cao@tum.de we can discuss it in detail if you would of can you tell me your email address?
Old   November 27, 2018, 09:18
the equation, you showed there has to be changed a bit if you are using for thermocapillary flows with constant d(sigma)/dT. I'll send you an email and would like to discuss it with you.
Old   May 6, 2019, 04:31
Default implemention of marangoni force
Navid
navidamin is on a distinguished road
Hey guys!
I am having the same problem. Kalpana, would you please also post here the correct implementation of the equation?
navidamin is offline   Reply With Quote
Old   May 6, 2019, 10:35
Originally Posted by navidamin View Post
Hey guys!
The equation mentioned by Cao is correct for a general Marangoni flows where you have a surface tension gradient. I have implemented that equation as it is in my solver. However, when you are going to validate, you have to use the thermocapillary flow cases provided in literature. In most cases, they used the assumption of d(sigma)/dT = constant. So there equation should be
ST_force = sigma_0*kappa*n + d(sigma)/dT (grad(T)-n(n.grad(T))
Mathematically both equations are correct given that sigma = sigma_0 + (d(sigma)/dT)* (T-T_0)
Hope it helped.
Kalpana
Old   May 6, 2019, 12:05
Navid
Hope it helped.
Kalpana
Yes, I have done the same. But my problem is how to add this to the Ueqn? the term ST_force that you mentioned above is finally a surfaceVectorfield, right? how can we add such type to momentum equation?
Old   May 6, 2019, 12:17
It can be done in two ways.
One is to include in the UEqn.H under fvVectorMatrix as volVectorField. The other way is to include in pEqn.H as a surfaceScalarField. Check how the normal surface tension force is implemented in interFoam in older openfoam versions (2.3.0 or 3.0)
Method 1
in UEqn.H
fvVectorMatrix UEqn
fvm::ddt(rho, U)
+ fvm::div(rhoPhi, U)
+ turbulence->divDevRhoReff(rho, U)
//include it here as a volVectorField
Method 2
in pEqn.H
surfaceScalarField phig
fvc::interpolate(interface.sigmaK())*fvc::snGrad(a lpha1)
// you can add your tangential component here.
- ghf*fvc::snGrad(rho)
)*rAUf*mesh.magSf()
then in UEqn.H (only if you use momentum predictor)
if (pimple.momentumPredictor())
solve
UEqn
fvc::reconstruct
//add it here
- fvc::snGrad(p_rgh)
) * mesh.magSf()
Kalpana
Old   May 6, 2019, 12:53
Navid
Method 1
in UEqn.H
fvVectorMatrix UEqn
fvm::ddt(rho, U)
Method 2
in pEqn.H
)*rAUf*mesh.magSf()
solve
UEqn
fvc::reconstruct
//add it here
) * mesh.magSf()
Kalpana
That's exactly my problem. in the term (grad(T)-n(n.grad(T)), n is a surfaceVectorField, right? so I have to interpolate grad(T) to a surfaceVectorField. then the result would be inevitably suraceVectorField. what I am getting wrong here?
Old   May 6, 2019, 12:57
You have to manually calculate n.
Kalpana
Old   May 7, 2019, 06:02
Default d(sigma)/dT Value
  #15
Navid
Kalpana
Thanks man, I could compile it. now I want to make sure it works. what sample cases did you use to validate?
Also, do you have any reference for d(sigma)/dT value?
Old   May 7, 2019, 09:58
There are so many literature on validation of tangential surface tension force. I cannot remember the specifics.
Kalpana
Old   May 14, 2019, 10:32
cyw
Yuanwei Cao
Hi, have you validated your solver? How is the result?
Cao
Old   October 29, 2019, 06:58
Nikhil Chitnavis
Nikhil2511 is on a distinguished road
hello,
I am using marangoni BC in simpleFoam solver, I am attaching my solver can anybody please tell whether it is correct way to define sigma(surface tension) as a function of temperature.
Info<< "Reading transportProperties\n" << endl;
IOdictionary transportProperties
IOobject
"transportProperties",
runTime.constant(),
mesh,
IOobject::MUST_READ_IF_MODIFIED,
IOobject::NO_WRITE
Info<< "Reading diffusivity DT\n" << endl;
dimensionedScalar DT
transportProperties.lookup("DT")
Info<< "Reading diffusivity betatn\n" << endl; ////// d(sigma)/dT
dimensionedScalar betatn
transportProperties.lookup("betatn")
Info<< "Reading diffusivity TRef\n" << endl;
dimensionedScalar TRef
transportProperties.lookup("TRef")
//////////////////////////////////////////////////////////////////////NC
Info<< "Reading diffusivity sigma\n" << endl;
dimensionedScalar sigma
transportProperties.lookup("sigma")
Info<< "Reading field Sg\n" << endl;
volScalarField Sg
IOobject
"Sg",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::AUTO_WRITE
sigma - betatn*(T-TRef)
thank you
Nikhil2511 is offline   Reply With Quote
Old   February 3, 2020, 09:08
Sebastian
BuzzB is on a distinguished road
Hey guys,
I'm also working on the implementation of the tangential surface tension terms in order to calculate marangoni driven convection.
I want to add them in the surfaceTensionForce() function in phaseSystem.C, since I want to use icoReactingMultiphaseInterFoam.
However, I'm having a hard time implementing it there.
Now, I came across this thread and recognized that you implemented the tangential component seperately in UEqn and pEqn.
It seems that you (kal1943335, cyw, navidamin) managed to get it to work correctly.
Would you mind sharing how exactly you have implemented the neccessary new terms?
Your help is very much appreciated
BuzzB is offline   Reply With Quote
Old   February 7, 2020, 10:43
Sebastian
Hey again,
just to give an update, i managed to implement the tangential surface tension force in the phaseSystem library. It works reasonable but is not yet validated, though.
marangoni vof
