Defining mesh motion diffusivity from file
Old   July 9, 2013, 03:07
Default Defining mesh motion diffusivity from file
cuba is on a distinguished road
Hi Everyone,
I am looking for a sample case where the mesh motion diffusivity (using laplaceFaceDecomposition) is defined from file for each point in the mesh?
You may think my case as a shoebox where the top stands still and bottom moves. My mesh is finer at the bottom.
Short side walls of this box are my inlet and outlet boundaries and the long side walls are the slip boundaries.
Thanks for the replies
Best
cuba is offline   Reply With Quote
Old   July 9, 2013, 04:14
akidess's Avatar
Anton Kidess
I don't know a tutorial case, but from what I can tell (looking at the code in 1.6-ext) the diffusivity is defined as a surfaceScalarField, i.e. per face. I'm not sure if there is a tool to set values on a surfaceScalarField (such as setFields for vol*Fields), but if there isn't it wouldn't be too hard to write a small tool specifically for your case.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   February 12, 2015, 05:00
Christoph Gradl
ChristophGradl is on a distinguished road
I am also looking for a sample case - did you found one?
Do you have another solution or workaround?
Thank you,
Chrisotph
ChristophGradl is offline   Reply With Quote
Old   October 24, 2023, 08:09
M. Montero
be_inspired is on a distinguished road
Hi. I hope someone could update this topic. How generate that file?
be_inspired is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
[swak4Foam] swak4Foam-groovyBC build problem zxj160 OpenFOAM Community Contributions 18 July 30, 2013 13:14
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 13:59
[swak4Foam] funkySetFields compilation error tayo OpenFOAM Community Contributions 39 December 3, 2012 05:18
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
