Running parallel HronTurekFsi3
Old   November 14, 2016, 18:26
Default Running parallel HronTurekFsi3
manu551 is on a distinguished road
Dear Foamers;
I need your help running HronTurek3 FsiFoam tutorial in parallel.
Here is how I modified the Allrun file:
#!/bin/sh
# Source tutorial run functions
. $WM_PROJECT_DIR/bin/tools/RunFunctions
# Get application name
application=`getApplication`
runApplication -l log.blockMesh.solid blockMesh -case ../solid
runApplication -l log.setSet.solid setSet -case ../solid -batch ../solid/setBatch
runApplication -l log.setToZones.solid setsToZones -case ../solid -noFlipMap
runApplication -l log.decomposeParFsi.solid decomposeParFsi -case ../solid -cellDist
runApplication blockMesh
runApplication setSet -batch setBatch
runApplication setsToZones -noFlipMap
runApplication decomposeParFsi -cellDist
cd ..
./makeLinks fluid solid
cd f*
# Build setInletVelocity function object
wmake libso ../setInletVelocity
runParallel $application 6
wait
#runApplication $application
runApplication -l log.reconstructPar.solid reconstructPar -region solid
wait
runApplication reconstructPar
cd ..
cp fluid{solid}.OpenFOAM fluid
# ----------------------------------------------------------------- end-of-file
Everything went well except for decomposeParFsi of solid mesh... It gave me this error:
--> FOAM FATAL ERROR:
Unknown global face zone plate-zone
Valid face zones are
1
plateZone
    From function domainDecomposition::decomposeMesh()
    in file decomposeMesh.C at line 495.
FOAM exiting
What was wrong? What can I do?
Thankyou.
manu551 is offline   Reply With Quote
Old   November 11, 2020, 07:17
Justyna Salachna
salachnaj is on a distinguished road
Hi, Any reply to your problem?
salachnaj is offline   Reply With Quote
Old   November 11, 2020, 09:23
Krapf is on a distinguished road
I suspect that he has written "plate-zone" somewhere, but it should actually be "plateZone".
Krapf is offline   Reply With Quote
error while running in parallel using openmpi on local mc 6 processors suryawanshi_nitin OpenFOAM 10 February 22, 2017 21:33
Running mapFields with Parallel Source and Parallel Target RDanks OpenFOAM Pre-Processing 4 August 2, 2016 05:24
running OpenFoam in parallel vishwa OpenFOAM Running, Solving & CFD 22 August 2, 2015 08:53
Unconsistent parallel jobs running time arnaud6 OpenFOAM Running, Solving & CFD 4 February 10, 2015 12:42
Problems running in parallel - missing controlDict Argen OpenFOAM Running, Solving & CFD 4 June 7, 2012 03:50
