November 11, 2020, 07:30 |
URGENT HELP gradSchemes Evaluation
Munaf
Rep Power: 6 |
I have come across many gradSchemes the problem i am trying to list them from most accurate ones to least accurate, i would appreciate if anyone can review the below list based on accuracy :-
1- Gauss linear 2- Gauss pointLinear 3- leastSquares 4- pointCellsLeastSquares 5-cellLimited<cubic> 1.5 Gauss linear 1 6- cellLimited leastSquare 1 7- cellLimited Gauss pointLinear 1 8- cellMDLimited Gauss linear 1 9- cellLimited Gauss linear 1 or if you are familiar with any of above maybe you can give an insight Thanks |
November 11, 2020, 08:31 |
Rodrigo
Rep Power: 16 |
May this be a good starting point for you?
https://www.openfoam.com/documentati...t-example.html |
November 11, 2020, 09:42 |
Munaf
Rep Power: 6 |
Thank you i checked the page but couldn't understand how to know which is more accurate than the other and how to compare maybe you can please explain a bit more thanks
November 11, 2020, 12:50 |
#4 | |
Santiago Lopez Castano
Rep Power: 15 |
leastSquares is the only, strictly, 2nd order accurate scheme in the list! Your new list: 1. leastSquare (the rest) |
November 11, 2020, 12:57 |
Munaf
Rep Power: 6 |
Thank you Santiago so what comes after if you can state another three that will be great
1. leastSquare 2. 3. 4. Thanks |
November 11, 2020, 12:59 |
Rep Power: 14 |
Sometimes you also crave for stability, of course, esp. if you are having to deal with dirtier meshes, so formal accuracy is not the only metric ...
November 11, 2020, 13:02 |
Rep Power: 15 |
November 11, 2020, 13:10 |
Munaf
Rep Power: 6 |
lets say i am using hexahedral as one option and polyhedral as another option so which schemes you would recommend for each starting from higher accuracy to less accuracy thank you again
Tecplot 360 2011 R2 preview with OpenFOAM data loader available for evaluation | scott_rumage | OpenFOAM Post-Processing | 50 | January 23, 2017 02:49 |
Urgent - Polyflow - particle tracking visualization -Urgent | shafaatht | ANSYS | 0 | October 13, 2010 04:56 |
Urgent, Urgent, a UDF problem, PLEASE HELP!!! | Max | FLUENT | 1 | September 24, 2010 20:30 |
Urgent...urgent...plss!!! | astronome | FLUENT | 0 | October 16, 2009 07:17 |
tmerge urgent urgent | jessica | FLUENT | 4 | July 15, 2006 13:37 |
