URGENT HELP gradSchemes Evaluation
Old   November 11, 2020, 07:30
Default URGENT HELP gradSchemes Evaluation
Munaf
mwmalkawi is on a distinguished road
I have come across many gradSchemes the problem i am trying to list them from most accurate ones to least accurate, i would appreciate if anyone can review the below list based on accuracy :-
1- Gauss linear
2- Gauss pointLinear
3- leastSquares
4- pointCellsLeastSquares
5-cellLimited<cubic> 1.5 Gauss linear 1
6- cellLimited leastSquare 1
7- cellLimited Gauss pointLinear 1
8- cellMDLimited Gauss linear 1
9- cellLimited Gauss linear 1
or if you are familiar with any of above maybe you can give an insight
Thanks
mwmalkawi is offline   Reply With Quote
Old   November 11, 2020, 08:31
Rodrigo
guin is on a distinguished road
May this be a good starting point for you?
https://www.openfoam.com/documentati...t-example.html
guin is offline   Reply With Quote
Old   November 11, 2020, 09:42
Munaf
Thank you i checked the page but couldn't understand how to know which is more accurate than the other and how to compare maybe you can please explain a bit more thanks
Old   November 11, 2020, 12:50
Santiago Lopez Castano
Santiago is on a distinguished road
1- Gauss linear
3- leastSquares
Thanks
leastSquares is the only, strictly, 2nd order accurate scheme in the list!
Your new list:
1. leastSquare
(the rest)
Santiago is offline   Reply With Quote
Old   November 11, 2020, 12:57
Munaf
Thank you Santiago so what comes after if you can state another three that will be great
1. leastSquare
2.
3.
4.
Thanks
Old   November 11, 2020, 12:59
Tobermory will become famous soon enough
Sometimes you also crave for stability, of course, esp. if you are having to deal with dirtier meshes, so formal accuracy is not the only metric ...
Tobermory is offline   Reply With Quote
Old   November 11, 2020, 13:02
1. leastSquare
2.
3.
4.
Thanks
very difficult to know if you dont say over what kind of mesh elements you expect to use the scheme!
Old   November 11, 2020, 13:10
Munaf
lets say i am using hexahedral as one option and polyhedral as another option so which schemes you would recommend for each starting from higher accuracy to less accuracy thank you again
Tecplot 360 2011 R2 preview with OpenFOAM data loader available for evaluation scott_rumage OpenFOAM Post-Processing 50 January 23, 2017 02:49
Urgent - Polyflow - particle tracking visualization -Urgent shafaatht ANSYS 0 October 13, 2010 04:56
Urgent, Urgent, a UDF problem, PLEASE HELP!!! Max FLUENT 1 September 24, 2010 20:30
Urgent...urgent...plss!!! astronome FLUENT 0 October 16, 2009 07:17
tmerge urgent urgent jessica FLUENT 4 July 15, 2006 13:37
