November 26, 2019, 03:08 |
Overset mesh refinement
Bagya Vivekanandhan
Rep Power: 6 |
Hey CFDians,
I am using OverIntDymFOAM to run a floating body tutorial. While i tried to run the simulation, I got this error as below: " Cell:864425 at0.455 0.38 0.3295) zone:0 changed from hole to calculated but there is no donor" I am not sure what this error means. Also, it would helpful if someone could tell me how to have the Background Mesh and the OversetMesh at a equal cell refinement. Any suggestions on this is much appreciated. Thank you. |
December 7, 2020, 18:28 |
mostafa raeisi
Rep Power: 11 |
Hi
Did you find a solution for the mentioned problem? Best regards |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 17:16 |
[snappyHexMesh] Edge Refinement | fracasce | OpenFOAM Meshing & Mesh Conversion | 3 | December 2, 2017 13:30 |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 11:14 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[snappyHexMesh] snappyHexMesh & Mesh around a missile | sasanghomi | OpenFOAM Meshing & Mesh Conversion | 2 | October 15, 2014 19:54 |
