Cleaning out timesteps in processor??? directories |
December 15, 2020, 06:18 |
Gerry Kan
Rep Power: 10 |
Howdy Foamers:
I am running a job with about 400+ subdomains. Sometimes when the run went wrong and I want to start the run from scratch, I need to remove the processor??? directories in order to (quickly) remove the timestep data, and rebuild them using decomposePar. This actually takes quite some time because of the number of subdomains involved. So this begs the question, whether there is a more convenient way to just remove the timestep files within the processor??? directories? Thanks in advance, Gerry. |
December 15, 2020, 09:01 |
Herpes Free Engineer
Rep Power: 12 |
I would not delete `processor*` directories if you do not change the mesh.
- If you want to replace the `processor*/0` directory from the new `0.orig` directory: -- `rm -rf processor*/<time> && restore0Dir -processor` -- You need to source `/bin/tools/RunFunctions` to use `restore0Dir`. - If you want to decompose fields only, and not the existing mesh: -- `decomposePar -fields` - If you want to perform decompositions in parallel: -- `mpirun -np X redistributePar -decompose -parallel` I am sure the number of methods reducing the computational effort can further be increased. Hope it helps a bit.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
Write field data at a few specific timesteps | gary7 | OpenFOAM | 5 | March 11, 2020 12:31 |
How to load only few timesteps from all timesteps that have been loaded in CFD-Post? | vuongcongdat | FLUENT | 2 | August 1, 2019 23:46 |
Transient analysis - timesteps vs iteration | Jiricbeng | CFX | 6 | July 14, 2017 06:35 |
Problem with maximum number of Timesteps | Phantalor | CFX | 5 | July 13, 2013 07:15 |
Adaptive Timesteps | swiss_zhang | CFX | 8 | August 30, 2011 06:51 |
