Overlapping rotating domains using AMI in OF6
Old   December 13, 2018, 08:37
Default Overlapping rotating domains using AMI in OF6
Thomas Sprich
Swift is on a distinguished road
Dear OpenFoamers,
I seem to remember reading that OpenFoam 6 could handle overlapping rotating meshes using AMI, but cannot verify or find anything regarding this when I search now.
Does anyone know if this is possible in the new releases of OpenFoam or OpenFoam-dev?
I found this post which provides a possible method of doing this which I will have to read and understand more thoroughly:
Dynamic Mesh for a Gear Pump
And this page where someone else had a similar problem:
Overlapping AMIs
but was referred to the link above.
I have read the release notes for openFOAM 4 - 6, but can't see anything there either.
Does anyone have any more information/advice on how to tackle this sort of problem.
Sorry if these questions should have been posted the above threads. I didn't want to resurrect old threads.
Thanks,
Thomas
Swift is offline   Reply With Quote
Old   December 13, 2018, 08:48
Peter Baskovich
pete20r2 is on a distinguished road
Maybe something like overset mesh?
https://www.openfoam.com/releases/op...6/numerics.php
pete20r2 is offline   Reply With Quote
Old   December 13, 2018, 09:15
Thomas Sprich
Hi Pete,
Yes, that is what I was looking for. I'm going to try see if I can get that running tomorrow.
Thanks very much for your help.
Thomas
Old   December 17, 2020, 05:03
mengge
mengge is on a distinguished road
Hi there,
I just learned a little bit about the method to handle the problem of solid body motion in OpenFOAM, and I'm going to try with overset meshes.
However, since I've got some modified solvers based on OF6, I'm wondering if OF6 can deal with overset meshes? As far as I know it is not possible, can it?
Thanks very much!
mengge is offline   Reply With Quote
Old   December 17, 2020, 06:59
Thomas Sprich
Hi mengge,
I would not expect it to work with OF6. overset is only available in ESI openfoam (www.openfoam.com).
Regards,
Thomas
Old   December 17, 2020, 07:11
mengge
Originally Posted by Swift View Post
Hi mengge,
Regards,
Thomas
Hi Thomas,
Thanks for your reply.Then I guess I will have to modify the solvers.
Best regards,
mengge
ami
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 04:13
Translating and Rotating AMI HiddenSquid OpenFOAM Pre-Processing 1 October 25, 2017 03:59
Car external aerodynamic with wheel spinning issue hokhay FloEFD, FloWorks & FloTHERM 2 August 18, 2016 04:23
[mesh manipulation] Combining two meshes for AMI of rotating turbine mahtin360 OpenFOAM Meshing & Mesh Conversion 0 October 2, 2014 03:06
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 09:34
