parallel running error
Old   March 1, 2022, 10:55
Default parallel running error
Boucetta Lahcene
B6_lacen is on a distinguished road
Hello everyone
I try to do a parallel simulation with 4 processors but it shows me this error, knowing that I do the same thing with a simple case and it works. But with my main case it doesn't work :/
Can someone help me plz. thanks
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 6
\\/ M anipulation |
Build : 6-fa1285188035
Exec : pimpleFoam -parallel
Date : Mar 01 2022
Time : 16:37:02
Host : "DS-CZC8188F4Q"
PID : 11549
I/O : uncollated
Case : /home/lahcene_boucetta/Bureau/cas_test/first_airfoil_nw/test1_urans
nProcs : 4
Slaves :
3
"DS-CZC8188F4Q.11550"
"DS-CZC8188F4Q.11551"
"DS-CZC8188F4Q.11552"
Pstream initialized with:
floatTransfer : 0
nProcsSimpleSum : 0
commsType : nonBlocking
polling iterations : 0
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
PIMPLE: No convergence criteria found
PIMPLE: Operating solver in PISO mode
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type RAS
Selecting RAS turbulence model kOmegaSST
Selecting patchDistMethod meshWave
RAS
RASModel kOmegaSST;
turbulence on;
printCoeffs on;
alphaK1 0.85;
alphaK2 1;
alphaOmega1 0.5;
alphaOmega2 0.856;
gamma1 0.5555555556;
gamma2 0.44;
beta1 0.075;
beta2 0.0828;
betaStar 0.09;
a1 0.31;
b1 1;
c1 10;
F3 false;
No MRF models present
No finite volume options present
Courant Number mean: 6.224786192e-07 max: 0.4127096893
--> FOAM Warning :
From function void* Foam::dlOpen(const Foam::fileName&, bool)
in file POSIX.C at line 1234
dlopen error : /opt/openfoam6/platforms/linux64GccDPInt32Opt/lib/libsixDoFRigidBodyState.so: undefined symbol: _ZN4Foam27sixDoFRigidBodyMotionSolver8typeNameE
--> FOAM Warning :
From function bool Foam::dlLibraryTable:pen(const Foam::fileName&, bool)
in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 105
could not load "libsixDoFRigidBodyState.so"
--> FOAM Warning :
From function bool Foam::dlLibraryTable:pen(const Foam::dictionary&, const Foam::word&, const TablePtr&) [with TablePtr = Foam::HashTable<Foam::autoPtr<Foam::functionObject > (*)(const Foam::word&, const Foam::Time&, const Foam::dictionary&), Foam::word, Foam::string::hash>*]
in file lnInclude/dlLibraryTableTemplates.C at line 62
[1]
[1]
[1] --> FOAM FATAL ERROR:
[1] Unknown function type sixDoFRigidBodyState
Valid functions are :
6
patchProbes
probes
psiReactionThermoMoleFractions
rhoReactionThermoMoleFractions
sets
surfaces
[1]
[1]
[1] From function static Foam::autoPtr<Foam::functionObject> Foam::functionObject::New(const Foam::word&, const Foam::Time&, const Foam::dictionary&)
[1] in file db/functionObjects/functionObject/functionObject.C at line 100.
[1]
FOAM parallel run exiting
[1]
[2]
[2]
[2] --> FOAM FATAL ERROR:
[2] Unknown function type sixDoFRigidBodyState
6
patchProbes
probes
sets
surfaces
[2]
[2]
[2] From function static Foam::autoPtr<Foam::functionObject> Foam::functionObject::New(const Foam::word&, const Foam::Time&, const Foam::dictionary&)
[2] in file db/functionObjects/functionObject/functionObject.C at line 100.
[2]
[2]
[3]
[3]
[3] --> FOAM FATAL ERROR:
[3] Unknown function type sixDoFRigidBodyState
6
patchProbes
probes
sets
surfaces
[3]
[3]
[3] From function static Foam::autoPtr<Foam::functionObject> Foam::functionObject::New(const Foam::word&, const Foam::Time&, const Foam::dictionary&)
[3] in file db/functionObjects/functionObject/functionObject.C at line 100.
[3]
[3]
[0]
[0]
[0] --> FOAM FATAL ERROR:
[0] Unknown function type sixDoFRigidBodyState
6
patchProbes
probes
sets
surfaces
[0]
[0]
[0] From function static Foam::autoPtr<Foam::functionObject> Foam::functionObject::New(const Foam::word&, const Foam::Time&, const Foam::dictionary&)
[0] in file db/functionObjects/functionObject/functionObject.C at line 100.
[0]
[0]
Could not open library "libsixDoFRigidBodyState.so"
MPI_ABORT was invoked on rank 3 in communicator MPI COMMUNICATOR 3 SPLIT FROM 0
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
[DS-CZC8188F4Q:11544] 2 more processes have sent help message help-mpi-api.txt / mpi-abort
[DS-CZC8188F4Q:11544] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
B6_lacen is offline   Reply With Quote
[OpenFOAM] ParaView command in Foam-extend-4.1 mitu_94 ParaView 0 March 4, 2021 13:46
long error when using make-install SU2_AD. tomp1993 SU2 Installation 3 March 17, 2018 06:25
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 07:24
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 12:34
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
