March 1, 2022, 10:55 |
parallel running error
Boucetta Lahcene
Rep Power: 4 |
Hello everyone
I try to do a parallel simulation with 4 processors but it shows me this error, knowing that I do the same thing with a simple case and it works. But with my main case it doesn't work :/ Can someone help me plz. thanks /*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 6-fa1285188035 Exec : pimpleFoam -parallel Date : Mar 01 2022 Time : 16:37:02 Host : "DS-CZC8188F4Q" PID : 11549 I/O : uncollated Case : /home/lahcene_boucetta/Bureau/cas_test/first_airfoil_nw/test1_urans nProcs : 4 Slaves : 3 ( "DS-CZC8188F4Q.11550" "DS-CZC8188F4Q.11551" "DS-CZC8188F4Q.11552" ) Pstream initialized with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking polling iterations : 0 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 PIMPLE: No convergence criteria found PIMPLE: Operating solver in PISO mode Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type RAS Selecting RAS turbulence model kOmegaSST Selecting patchDistMethod meshWave RAS { RASModel kOmegaSST; turbulence on; printCoeffs on; alphaK1 0.85; alphaK2 1; alphaOmega1 0.5; alphaOmega2 0.856; gamma1 0.5555555556; gamma2 0.44; beta1 0.075; beta2 0.0828; betaStar 0.09; a1 0.31; b1 1; c1 10; F3 false; } No MRF models present No finite volume options present Courant Number mean: 6.224786192e-07 max: 0.4127096893 --> FOAM Warning : From function void* Foam::dlOpen(const Foam::fileName&, bool) in file POSIX.C at line 1234 dlopen error : /opt/openfoam6/platforms/linux64GccDPInt32Opt/lib/libsixDoFRigidBodyState.so: undefined symbol: _ZN4Foam27sixDoFRigidBodyMotionSolver8typeNameE --> FOAM Warning : From function bool Foam::dlLibraryTable:pen(const Foam::fileName&, bool) in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 105 could not load "libsixDoFRigidBodyState.so" --> FOAM Warning : From function bool Foam::dlLibraryTable:pen(const Foam::dictionary&, const Foam::word&, const TablePtr&) [with TablePtr = Foam::HashTable<Foam::autoPtr<Foam::functionObject > (*)(const Foam::word&, const Foam::Time&, const Foam::dictionary&), Foam::word, Foam::string::hash>*] in file lnInclude/dlLibraryTableTemplates.C at line 62 [1] [1] [1] --> FOAM FATAL ERROR: [1] Unknown function type sixDoFRigidBodyState Valid functions are : 6 ( patchProbes probes psiReactionThermoMoleFractions rhoReactionThermoMoleFractions sets surfaces ) [1] [1] [1] From function static Foam::autoPtr<Foam::functionObject> Foam::functionObject::New(const Foam::word&, const Foam::Time&, const Foam::dictionary&) [1] in file db/functionObjects/functionObject/functionObject.C at line 100. [1] FOAM parallel run exiting [1] [2] [2] [2] --> FOAM FATAL ERROR: [2] Unknown function type sixDoFRigidBodyState Valid functions are : 6 ( patchProbes probes psiReactionThermoMoleFractions rhoReactionThermoMoleFractions sets surfaces ) [2] [2] [2] From function static Foam::autoPtr<Foam::functionObject> Foam::functionObject::New(const Foam::word&, const Foam::Time&, const Foam::dictionary&) [2] in file db/functionObjects/functionObject/functionObject.C at line 100. [2] FOAM parallel run exiting [2] [3] [3] [3] --> FOAM FATAL ERROR: [3] Unknown function type sixDoFRigidBodyState Valid functions are : 6 ( patchProbes probes psiReactionThermoMoleFractions rhoReactionThermoMoleFractions sets surfaces ) [3] [3] [3] From function static Foam::autoPtr<Foam::functionObject> Foam::functionObject::New(const Foam::word&, const Foam::Time&, const Foam::dictionary&) [3] in file db/functionObjects/functionObject/functionObject.C at line 100. [3] FOAM parallel run exiting [3] [0] [0] [0] --> FOAM FATAL ERROR: [0] Unknown function type sixDoFRigidBodyState Valid functions are : 6 ( patchProbes probes psiReactionThermoMoleFractions rhoReactionThermoMoleFractions sets surfaces ) [0] [0] [0] From function static Foam::autoPtr<Foam::functionObject> Foam::functionObject::New(const Foam::word&, const Foam::Time&, const Foam::dictionary&) [0] in file db/functionObjects/functionObject/functionObject.C at line 100. [0] FOAM parallel run exiting [0] Could not open library "libsixDoFRigidBodyState.so" -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 3 in communicator MPI COMMUNICATOR 3 SPLIT FROM 0 with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- [DS-CZC8188F4Q:11544] 2 more processes have sent help message help-mpi-api.txt / mpi-abort [DS-CZC8188F4Q:11544] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages |
[OpenFOAM] ParaView command in Foam-extend-4.1 | mitu_94 | ParaView | 0 | March 4, 2021 13:46 |
long error when using make-install SU2_AD. | tomp1993 | SU2 Installation | 3 | March 17, 2018 06:25 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 07:24 |
checking the system setup and Qt version | vivek070176 | OpenFOAM Installation | 22 | June 1, 2010 12:34 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 06:31 |
