Room-Suction
Old   January 11, 2021, 11:47
Post Room-Suction
_Revolution_ is on a distinguished road
Hello together,
I have a couple of questions about the definition of the initial and boundary conditions for my problem. Basically I want to simulate a suction for a room. At the inlet_1 and outlet_1 I want to define a fix velocity or a volumetric flow. In order to be able to equalize the volume in the room, air should flow in again through the other two inlets (inlet_2 and inlet_3 > free convection).
I use OpenFoam-V8 and I want to solve the problem laminar with pimpleFoam. My first attempt for the definition looks like this:
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 8
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet_1
type fixedValue;
value uniform (0 0.1 0);
inlet_2
type pressureInletOutletVelocity;
value uniform (0 0 0);
inlet_3
outlet_1
type fixedValue;
value uniform (-15.0 0 0);
suction
type noSlip;
walls
type noSlip;
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
inlet_1
type zeroGradient;
inlet_2
type uniformTotalPressure;
p0 uniform -1;
inlet_3
p0 uniform -1;
outlet_1
type fixedValue;
value uniform 0;
suction
type zeroGradient;
walls
type zeroGradient;
Can somebody help me at the definition of the initial and boundary conditions? What have I to change in the conditions so that I can simulate the problem or run the simulation correctly?
Thanks in advance for your help.
_Revolution_ is offline   Reply With Quote
Radiation and convection heat transfer in a room through heat pipe mankaran90 FLUENT 0 February 26, 2018 05:08
[DesignModeler] Designing a room (design & mesh) Andorebr ANSYS Meshing & Geometry 2 October 1, 2015 11:13
[ICEM] Ogride in of a room in ICEM CFD metmet ANSYS Meshing & Geometry 3 July 31, 2014 14:00
[GAMBIT] Object in room with that object being the purpose of investigation fluentgambituser ANSYS Meshing & Geometry 3 August 24, 2011 01:52
Salome and Code Saturne simulation of simple room and objects cristian.ocnarescu Main CFD Forum 0 June 21, 2010 10:19
