non constant object moving velocity set in pointDisplacement
Old   February 2, 2021, 02:05
Default how to do drivenLinearMotion set in pointDisplacement
cyh
cyhpku is on a distinguished road
Hi everyone,in short can anyone give an example of drivenLinearMotion?
below is its source code .H:
public solidBodyMotionFunction
// Private data
//- Name of the meshObject to dum CofG velocity
word CofGvelocity_;
//- Normal plane direction to restrict movement on a plane
vector normal_;
//- Uniform vector to follow
uniformDimensionedVectorField CofGvel_;
//- Last displacement
mutable vector displacement_;
and here is its .C:
Foam::septernion
Foam::solidBodyMotionFunctions::drivenLinearMotion ::transformation() const
scalar deltaT = time_.deltaT().value();
vector velocity = CofGvel_.value();
// Take out normal component
if (mag(normal_) > SMALL)
velocity = CofGvel_.value() - ((CofGvel_.value() & normal_)*normal_);
DebugInFunction << "Vel on plane :" << velocity << endl;
// Translation of centre of gravity with constant velocity
//const vector displacement = velocity*t;
displacement_ += velocity*deltaT;
my understanding is CofGvel is the object moving velocity and displacement is calculated each moment by +=velocity*deltaT,but when i set it and use pimpleFoam it report error like this:
--> FOAM FATAL ERROR:
Continuity error cannot be removed by adjusting the outflow.
Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow.
Total flux : 1e-300
Specified mass inflow : 5.60342e-28
Specified mass outflow : 4.12536e-28
Adjustable mass outflow : 0
From bool Foam::adjustPhi(Foam::surfaceScalarField&, const volVectorField&, Foam::volScalarField&)
in file cfdTools/general/adjustPhi/adjustPhi.C at line 110.
and here‘s my setting of pointdisplacement:
cylinder
type solidBodyMotionDisplacement;
solidBodyMotionFunction drivenLinearMotion;
CofGvelocity haak;
normal (0 0 1);
CofGvel (this->db().time().value() this->db().time().value() 0);
displacement (0 0 0);
my purpose is to make the object move with velocity (t,t,0),can anyone tell how should i set it or please give me an example of it?there’s no such example in tutorial files.Other parts are ok,if i set it like this the whole case run without problem:
cylinder
solidBodyMotionFunction linearMotion;
velocity (1 2 0);
So anyone help plz..
Last edited by cyhpku; February 2, 2021 at 23:14. Reason: i find something more exactly to describe my problem
cyhpku is offline   Reply With Quote
serial udf to parallel udf radioss Fluent UDF and Scheme Programming 10 January 19, 2019 08:56
does Hyperthreading affect the application of UDF? SJSW Fluent UDF and Scheme Programming 11 October 10, 2018 22:28
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 09:53
How to show the transient case? H.P.LIU Phoenics 7 July 13, 2010 04:31
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
