Assigning values to read-only location
Old   February 10, 2021, 08:20
Default Assigning values to read-only location
Saumava Dey
saumavadey is on a distinguished road
Parts of my code read as:
volScalarField h
IOobject
"h",
runTime.timeName(),
mesh,
IOobject::MUST_READ,
IOobject::AUTO_WRITE
mesh
fvScalarMatrix h_Eqn
(rho_frac*F)*fvm::ddt(h)
fvm::laplacian(Ku,h)
rho_frac*grad_Kuz
rhoC_frac*q
h_Eqn.relax();
h_Eqn.solve();
Now after solving for h, I need to reassign the values of h before it passes on to the next time-step. The values of the h field which are having values less than -1 are to be set to -1. This modified h field has to be passed on the next time step.
How to accomplish this?
saumavadey is offline   Reply With Quote
How to read values in a file to a source file? qkrtjdrns OpenFOAM Running, Solving & CFD 3 April 8, 2020 04:18
using chemkin JMDag2004 OpenFOAM Pre-Processing 2 March 8, 2016 22:38
Read gradient values of constantAlphaContactAngle styleworker OpenFOAM Programming & Development 0 November 25, 2013 08:26
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 10:52
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
