chtMultiRegionFoam natural convection negative initial temperature
Like Tree4Likes
  • 1 Post By Tobi
  • 2 Post By keitaro7_14
  • 1 Post By saidc.
Old   February 8, 2021, 05:09
Post chtMultiRegionFoam natural convection negative initial temperature
saidc
saidc. is on a distinguished road
I'm trying to do turbulent natural convection heat transfer case with chtMultiRegionFoam. The geometry is here. By the way geometry is 3D. The sphere that is at the origin of the coordinate system is 1023.15 K and the fluid (helium) is 523.15K.
  • It starts well to run but after few iterations initial temperature value decreasing. Although the decrease is small, the initial temperature value eventually becomes negative. I first thought it might be because of the mesh, so i refined the mesh but result was the same. Then i tried temperature limits on fvOptions, but this didn't work either.
  • Another problem is the results aren't looks like LES. I've researched similar cases and if we were to compare, my results are disgusting, behave like laminar.
For curiosity I changed my case to cavity and made all boundaries wall (adiabatic bc) and it works much better than inlet-outlet one. Unfortunately I want to do this with patches.
I think i'm doing something wrong on boundary conditions but i can't figure it out. What should I change, what should I try? I am open to any suggestions. Files are attached.
Kind regards,
Said.
For quick look:
fluid/T
internalField   uniform $Tinitial;
boundaryField
    inlet
        type            fixedValue;
        value           uniform $Tinitial;
    outlet
        type            inletOutlet;
        inletValue      uniform $Tinitial;
	wall
        type           zeroGradient;
    fluid_to_sphere
        type            compressible::turbulentTemperatureCoupledBaffleMixed;
        neighbourFieldName T;
        kappa           kappa;
        Tnbr            T;
fluid/p_rgh
internalField   uniform $pInitial;
boundaryField
    outlet
        type            fixedValue;
        value           uniform $pInitial;
    inlet
        type            fixedFluxPressure;
        gradient        uniform 0;
    wall
        gradient        uniform 0;
    fluid_to_sphere
        gradient        uniform 0;
fluid/p
boundaryField
    outlet
        type            calculated;
    inlet
        type            calculated;
    wall
        type            calculated;
    fluid_to_sphere
        type            calculated;
fluid/U
internalField   uniform (0 0 0);
boundaryField
    inlet
        type            fixedValue;
        value           uniform (0 0 0);
    outlet
        type        pressureInletOutletVelocity;
        inletValue      uniform (0 0 0);
    wall
        type 	fixedValue;
    akiskan_to_kure
        type 	fixedValue;
saidc. is offline   Reply With Quote
Old   February 8, 2021, 06:35
Domenico Lahaye
dlahaye is on a distinguished road
What do mean by "Then i tried temperature limits on fvOptions, but this didn't work either." ?
dlahaye is offline   Reply With Quote
Old   February 8, 2021, 06:58
saidc
Hi dlahaye,
When i add temperature limit for fluid region, solver stops iteration after like 200 iterates. I mean 0 iteration, all parameters are stay same. For example, first 200 iteration initial temperature value decreasing but still positive, after 200 iteration initial temperature is becomes negative, after last iteration parameteres never change.
kind regards,
Said.
Old   February 8, 2021, 08:17
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Check out your fluid field in the domain? The negative temperature should occur in e.g. some cell or due to unphysical values for p and U. A work-around to fix your problem is to start with another solver (without your sphere). E.g., rhoSimpleFoam/rhoPimpleFoam. I supose that there is a problem somewhere else and the outcome destroyes your energy equation. You can also test with "incompressiblePerfectGas".
saidc. likes this.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   February 8, 2021, 11:59
JuanMi
keitaro7_14 is on a distinguished road
Please attach a runnable example if you want us to help you, with the corresponding scripts (Allrun, etc.). You uploaded a case which is not directly runnable.
A priori your case does not seem too complicated.
Tobi and saidc. like this.
keitaro7_14 is offline   Reply With Quote
Old   February 8, 2021, 14:11
Post
saidc
Hi Tobi and Juan,
Case file is 85 mb so i can't upload here. link, this is github download link. Rar file has everything you need, just download and type ./Allrun.
Also i'll try Tobi's advice as soon as possible.
kind regards,
Said.
Tobi likes this.
Old   February 9, 2021, 06:14
Peter Hess
peterhess is on a distinguished road
Hello Sadic
In:
templates\0\fluid
p_rgh is overall 0.
This is not allowed and should be 1.013e5 (if zou have atmospharic pressure).
That is the main resion for the negative temperature in this solver.
Regards
Peter
peterhess is offline   Reply With Quote
chtmultiregionfoam, heat tranfer, les, natural convectin
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" bigphil OpenFOAM CC Toolkits for Fluid-Structure Interaction 686 December 22, 2022 09:10
chtMultiRegionSimpleFoam turbulent case Aditya Patil OpenFOAM Running, Solving & CFD 6 April 24, 2017 22:13
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 02:50
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 13:58
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
