February 16, 2021, 06:09 |
adding heat flux to fvOptions
george
Rep Power: 5 |
I've a heat transfer case between solid and fluid region. I'm using Code:
compressible::turbulentTemperatureCoupledBaffleMixed; I searched with this command Code:
chtMultiRegionFoam -listFvOptions Also when I try to do this with externalWallHeatFluxTemperature boundary condition, I get this error Code:
Patch field for T on fluid_to_solid is of type compressible::turbulentTemperatureCoupledBaffleMixed The neighbouring patch field T on solid_to_fluid is required to be the same, but is currently of type externalWallHeatFluxTemperature Is there a way adding heat flux (W/m2) to solid region with fvOptions? Best regard |
chtmultiregionfoam, heat flux, heat transfer |
Measure of Heat Flux on a surface | MathieuCrslt | FLUENT | 0 | October 10, 2018 05:58 |
How do you use heat flux as a boundary condition in a non-wall area in UDF? | JuBong | Fluent UDF and Scheme Programming | 2 | July 2, 2018 21:15 |
Doubt - Variable Heat Flux input - UDF | Neethu_N | FLUENT | 1 | December 19, 2017 11:48 |
conjugateHeatFoam + interFoam | farhagim | OpenFOAM Programming & Development | 15 | July 19, 2016 07:55 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
