How to add a new region at a given time ?
Old   February 19, 2021, 21:33
Default How to add a new region at a given time ?
amanda
zhhzhc is on a distinguished road
Dear all,
In my problem, the physical domain includes 1 big cylinder (denoted as C_0, filled with gas at low pressure(101 Kpa)) and 10 small tanks (denoted as tank_i, i = 0, 1, ..., 9, filled with gas at 1 Mpa).
The simulation process is to release the high pressure gas of each tank at a given time T_i.
At T_0, the computational domain is: C_0 + tank_0,
At T_i, the domain is : C_0 + tank_0 + tank_1 + ... + tank_i;
That is to say, the computationl mesh will change at time T_i.
My question is, which topoChangeFvMesh should I use? My I have your suggestion on implementing such simulation? Or are there any similar examples in the tutorial directory of openfoam?
Thank you very much!
Best,
Hong
zhhzhc is offline   Reply With Quote
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[PyFoam] and paraview eelcovv OpenFOAM Community Contributions 28 May 30, 2016 10:23
Stuck in a Rut- interDyMFoam! xoitx OpenFOAM Running, Solving & CFD 14 March 25, 2016 08:09
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
