Setting origProcID by using a solidParticleInterFoam-solver |
March 11, 2021, 07:15 |
#1 | |
Sarah Falk
Rep Power: 6 |
Hi everyone,
I try to implement a solidParticleInterFoam-Solver by using this tutorial: http://www.tfd.chalmers.se/~hani/kur...iclesInVOF.pdf . Now I want to simulate the (solid)damBreak as it is described in the tutorial, but I'm getting the following error-message and don't know how to fix the problem: --> FOAM FATAL ERROR: Size of origProcId field 0 does not match the number of particles 2 From function void Foam::Cloud<ParticleType>::checkFieldIOobject(cons t Foam::Cloud<ParticleType>&, const Foam::IOField<DataType>&) const [with DataType = int; ParticleType = Foam::solidParticle] in file /home/ubuntu/OpenFOAM/OpenFOAM-6/src/lagrangian/basic/lnInclude/CloudIO.C at line 191. FOAM aborting My "origProcID"-File looks like that: Quote:
I have noticed, that the error-message doens't change, when I write an other number instead of 0. I also tried two numbers or other brackets. So I think, that origProcID-field is not setting correctly, but I have no idea, how I can checkt or change it. Have one of you any idea how I can fix my problem? I am thankfull for any kind of help! |
origprocid, solidparticlecloud, solidparticlefoam |
fluent solver setting for external aerodynamics on a race car. | Ahmed Jamal | FLUENT | 5 | March 26, 2016 03:13 |
Interfoam blows on parallel run | danvica | OpenFOAM Running, Solving & CFD | 16 | December 22, 2012 02:09 |
Quarter Burner mesh with periosic condition | SamCanuck | FLUENT | 2 | August 31, 2011 11:34 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
why the solver reject it? Anyone with experience? | bearcat | CFX | 6 | April 28, 2008 14:08 |
