[OpenFOAM v8] Volumetric Heat Generation
Old   April 16, 2021, 10:53
Default [OpenFOAM v8] Volumetric Heat Generation
Ali
aligs2920 is on a distinguished road
I have a model which looks very much like a basic flow around a cylinder problem. But my cylinder is solid so I am modelling conjugate heat transfer.
As per the title, does anyone know how to enable volumetric heat generation inside the solid so that the heat travels through the solid to the surface and washed away using a fluid.
I have done the basic flow over the cylinder tutorials and CHT tutorials and have validated them. But I am not sure how to generate heat inside a solid.
I am very new to openfoam and trying to do this before moving onto CHT with complex geometries.
aligs2920 is offline   Reply With Quote
cht, heat generation, openfoam v8, solid
heat not balanced in the chtMultiRegionSimpleFoam solver carye OpenFOAM 19 September 26, 2019 04:25
Unsteady problem with volumetric heat source Jonathan94 STAR-CCM+ 1 July 21, 2018 02:26
heat generation rate in the wall boundary conditions, what this? serguei Fluent Multiphase 3 September 10, 2015 16:24
How to Define heat generation rate that changes with the system coordinate. a19910112a OpenFOAM Running, Solving & CFD 2 December 12, 2014 03:22
Heat Generation rate in W/m³ ashghan OpenFOAM Programming & Development 0 June 27, 2014 05:42
