Unacceptable results using multiphaseEulerFoam
Old   April 22, 2021, 13:37
Default Unacceptable results using multiphaseEulerFoam
Mohsen Zarepour
moz455 is on a distinguished road
I am working on simulating the pseudo-2d fluidized bed presented by Laverman et al. using the multiphaseEulerFoam solver. Although the time-averaged solid volume fractions are in an acceptable agreement with the literature data, the solid averaged velocity profile does not seem good. I have checked every thing in the settings but I cannot make it better. I appreciate if any experienced guy gives me some hint on this issue.
Cheers,
Mohsen
moz455 is offline   Reply With Quote
Old   April 23, 2021, 12:44
Mohsen Zarepour
Is anyone who works with the multiphaseEulerFoam here?
Old   April 23, 2021, 13:44
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
Could you please provide a complete and minimal set of information, so that we can reproduce the issue, if possible?
I don't think any useful suggestion can be made based on the current problem description.
Some of the links below may help?
HPE is offline   Reply With Quote
Old   April 23, 2021, 14:06
Mohsen Zarepour
file.zip
Thank you for your prompt response. I am working on the simulation of Laverman pseudo-2D fluidized bed. Unfortunately the averaged velocity in y direction is not in an acceptable agreement with the experimental data and the numerical results of the literature. I have attached my results and the literature results. Sorry for the bad format of my results. The averaged velocity unit in my chart is (m/s) while it is (cm/s) in the other plot. The averaged volume fraction is in acceptable agreement with the literature.
I am not sure what is wrong in my settings but I have checked everything and the input values are correct. I appreciate if you can guide me to solve this issue. I have spent a lot of time on it. The run files are also attached.
Old   April 24, 2021, 00:55
Utkan Caliskan
dscian is on a distinguished road
I would change CarnahanStarling radial model to LunSavage and use a turbulence model for the air phase. Also, is your alphaMinFriction (0.6) from the literature?
dscian is offline   Reply With Quote
Old   April 25, 2021, 13:19
Mohsen Zarepour
Thank you ! Yes, it is 0.6 from he literature. I think changing the air flow regime to turbulence did not work. The deviation from the literature result is big. Have you ever validated the results of multiphaseEulerFoam?Do you think if I shoudl switch to version & from the version I am using now, version 8?
fluidized beds, multiphaseeulerfoam, openfoam
Validating the results of numerical modeling compared to the results of another model ENG.AHMAD FLUENT 0 June 22, 2020 16:49
bad heat transfer results with low y+ me45 OpenFOAM Running, Solving & CFD 0 April 29, 2020 11:56
multiphaseEulerFoam - Different results between v6 and v7 PositronCascade OpenFOAM Running, Solving & CFD 0 April 10, 2020 04:34
interFoam simulation yields inconsistent results for alpha1 surface Ralinus OpenFOAM Running, Solving & CFD 8 January 13, 2014 08:54
CFX cylinder or sphere benchmark results Mel CFX 1 August 8, 2005 18:47
