NACA0012 does not get the result of the stall
Old   May 9, 2021, 04:18
Default NACA0012 does not get the result of the stall
cheng
cheng1 is on a distinguished road
Hello everyone, I am now using openfoam to compare with experimental data. The results compare well before the stall. But when there is a stall situation and the lift coefficient should decrease, my lift coefficient is still increasing. Can someone tell me why this is. I am using simpleFoam, SA model.
cheng1 is offline   Reply With Quote
Old   May 9, 2021, 11:17
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
I don't think there is a RANS or even hybrid RANS-LES setup that can predict the polar coefficients correctly for a given airfoil at stall and post-stall regions.
HPE is offline   Reply With Quote
Old   May 9, 2021, 14:28
Tobermory will become famous soon enough
I think that you answered your own question there - it's not an OpenFOAM issue. Have a read up around the subject and you'll learn how difficult the problem is.
Tobermory is offline   Reply With Quote
openfoam,stall,sa
Can not get the right result at AoA=10 for RANS simulation of the NACA0012 liujmljm SU2 2 August 19, 2013 01:25
MRFSimpleFoam result checking Aadhavan OpenFOAM Running, Solving & CFD 0 December 8, 2012 04:52
2D External flow over NACA0012 DBFIU Main CFD Forum 7 July 13, 2011 13:26
Rotating Stall in Centrifugal Compressors Paul den Held Main CFD Forum 3 October 11, 2000 02:50
stall yin Main CFD Forum 1 May 10, 2000 03:03
