undefined div(((rho*nuEff)*dev2(T(grad(U))))) on cluster run |
August 29, 2018, 01:26 |
Gerry Kan
Rep Power: 10 |
Howdy Folks:
I am wondering if others experience a similar issue: I have a case using rhoPimpleFoam that works on (single and multiple) processes on a single machine. But the same job would choke on the following error: Code:
--> FOAM FATAL IO ERROR: keyword div((nuEff*dev2(T(grad(U))))) is undefined in dictionary "IOstream.divSchemes" file: IOstream.divSchemes from line 0[10] Code:
divSchemes { default none; div(phi,U) Gauss limitedLinearV 1; div(phi,h) Gauss limitedLinear 1; div(phi,K) Gauss limitedLinear 1; div(phid,p) Gauss limitedLinear 1; div(phi,epsilon) Gauss limitedLinear 1; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; } Thanks in advance, Gerry. |
August 29, 2018, 01:46 |
Peter Baskovich
Rep Power: 11 |
Maybe the excessive bracketing?
August 29, 2018, 02:52 |
#3 | |
Santiago Lopez Castano
Rep Power: 15 |
August 29, 2018, 04:00 |
anonymous
Rep Power: 14 |
I think you are using a different solver. Not what you need.
rhoPimpleFoam need div(((rho*nuEff)*dev2(T(grad(U))))) what you got in fvSchemes. But the solver what you are running need div((nuEff*dev2(T(grad(U))))). I think this is an incompressible solver. Can you check the beginning of the log? |
August 29, 2018, 04:45 |
Gerry Kan
Rep Power: 10 |
Folks:
I think I know what happened. I have a divergence definition for rho*nuEff, but I also need one for rho, so that OpenFOAM knows what to do with rho *and* nuEff. So my divSchemes looks like Code:
divSchemes { default none; div(phi,U) Gauss limitedLinearV 1; div(phi,h) Gauss limitedLinear 1; div(phi,K) Gauss limitedLinear 1; div(phi,rho) Gauss linear; div(phid,p) Gauss limitedLinear 1; div(phi,epsilon) Gauss limitedLinear 1; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; } Thanks for the ideas and at least this problem is solved, Gerry. |
May 28, 2021, 14:03 |
#6 | |
Mohsen Zarepour
Rep Power: 5 |
I want to use the "Gauss limitedLinear 1" scheme for div((nuEff*dev2(T(grad(U))))) but I get an error in simpleFoam. Whay does this scheme does not work for this term? Quote:
cluster, divschemes, fvscheme, mpi |
can not complie fluentDataToFoam in OF2.1.1 | hewei | OpenFOAM Pre-Processing | 20 | September 8, 2018 09:19 |
problem with turbulence models after compilation? | lfgmarc | OpenFOAM Programming & Development | 19 | November 20, 2013 00:50 |
OpenFOAM 1.6 ext - Compilation errors - Fedora 17(32bit) | toolpost | OpenFOAM Installation | 15 | September 21, 2012 09:38 |
[Commercial meshers] Conversion form .ccm to openFoam | ViktoriaE | OpenFOAM Meshing & Mesh Conversion | 1 | November 29, 2011 16:40 |
Building OpenFoAm on SGI Altix 64bits | anne | OpenFOAM Installation | 8 | June 15, 2006 09:27 |
