Ondulations/Pertubations in alpha.water surface |
May 28, 2021, 14:20 |
Rasmus Iwersen
Rep Power: 8 |
Hi all
I am experiencing some weird behaviour of the water/air interphase, see attached screenshot. I get some small ripples in my interphase between air and water. I am only using blockMesh to create the mesh, and using wave2Foam to calculate a streamfunction wave. Why to i see those ripples in the watersurface?? The models runs fine, no errors in checkMesh. I am running OpenFOAM v2012. Best Rasmus |
May 28, 2021, 16:52 |
Paulin FERRO
Rep Power: 5 |
Bad mesh. 1. Use regular cells without these large growth rates in the region of wave propagation. 2. increase the number of subcycle for alpha : 5 3. decrease your time step Good luck. Paulin |
June 3, 2021, 03:41 |
#3 | |
Rasmus Iwersen
Rep Power: 8 |
I resolved it from the first step you suggested. Usually I would try and keep an aspect ratio of 1, but the expansionrates were apparently the issue.. My timestep was set to dynamic. Thank you! |
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel | U.Golling | OpenFOAM Running, Solving & CFD | 52 | September 23, 2023 03:35 |
Unacceptable deltaT value (like 3e-107) Error | saidc. | OpenFOAM Bugs | 1 | March 6, 2020 01:38 |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
[snappyHexMesh] Problem with Sanpper, surface still Rough | Zephiro88 | OpenFOAM Meshing & Mesh Conversion | 7 | November 5, 2014 12:05 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 12:43 |
