June 16, 2021, 08:46 |
Particles lost in MPPICFoam
Rep Power: 8 |
Dear foamers,
I have encountered a strange behaviour with MPPICFoam. I set up a case, to fill a 2D column with lagranigan particles. When the cellValueSourceCorrection is set to off, particles suddenly vanish when the bed is packing. The particles, are not escaping through a patch. Does somebody know, how and why particles are removed / deleted? I attached the two case setups - everything was run in OpenFOAM 8. |
June 16, 2021, 12:50 |
Gerhard Holzinger
Rep Power: 28 |
I have no idea what causes the particle loss, however, the particles are not lost when you change the interpolation scheme for velocity to cellPointWallModified. This scheme was removed by commit fbf0020, and reinstated by commit 63b641a. Code:
interpolationSchemes { rho.air cell; U.air cellPointWallModified; mu.air cell; alpha.air cell; } |
June 17, 2021, 05:26 |
Rep Power: 8 |
thanks a lot! Do you think this should be reported as a bug? In my opinion, it is clearly unwanted and unphysical behaviour. I am wondering, if this also happens for other simulations, where you might not notice it that easily. |
October 4, 2023, 22:07 |
jinmingjie
Rep Power: 3 |
I met the same problem for cellValueSourceCorrection off as the turtorials. Do you know what cellValueSourceCorrection means? And if set cellValueSourceCorrection to on do some help to the problem? |
October 8, 2023, 09:43 |
Rep Power: 8 |
cellValueSourceCorrection updates the carrier velocity and temperature according to the latest transfer information in https://cpp.openfoam.org/v9/ThermoParcel_8C_source.html . As mentioned in the reply by Gerhard, if you change your U interpolation scheme the problem should be fixed. However, I am not sure why it does not work otherwise / where the particles get "lost". Best regards, Eva |
January 23, 2024, 07:00 |
jinmingjie
Rep Power: 3 |
It seems doesn't work for me. I change the interpolation scheme of U to cellPointWallModified, but the particle still get lost. Do you know is there any other reason? Could it be possible connected with my sliding mesh? |
January 23, 2024, 12:09 |
Rep Power: 8 |
Can you provide a minimal working example or more details on your setup (e.g. OF, version, particle dict)?
January 23, 2024, 19:05 |
jinmingjie
Rep Power: 3 |
Sure,
Version: Openfoam10, Based on InterFoam I coupled the kinematicCloud into the solver. storeGlobalposition is added. Sliding Mesh is used to rotate. particle dict is as your suggestion(CellPointWallModified for U) Sorry I cannot post an example, I will provide any information if you need and hope you can provide some suggestion. |
March 3, 2024, 12:45 |
#9 |
Rep Power: 8 |
I am sorry, I don't think I can help you without a sample case.
Did you check, if particles get lost over patches? With rotating mesh there are many more possibilities, where a problem could occur with the particles. Try to simplify the case and see if the problem still occurs there. |
lagrangian, mppicfoam, packing limit |
strange stuck particles on the rebound wall in MPPICFoam | carye | OpenFOAM Running, Solving & CFD | 12 | April 4, 2022 07:52 |
UDF in case with DPM modle | POSTHU | Fluent UDF and Scheme Programming | 0 | March 3, 2021 07:21 |
Particles lost in MPM model(macroscopic particle model)-ANSYS Fluent? | shanferns12 | FLUENT | 0 | February 24, 2019 09:48 |
MPPICFoam and particles visualisations | MrJeff | OpenFOAM Post-Processing | 7 | July 31, 2017 10:16 |
Lost .... new injected particles on last node_DPM Fluent | Jourak | FLUENT | 9 | December 13, 2016 10:56 |
