pimpleFoam with AMI has Floating point Exteption Point error |
June 18, 2021, 08:18 |
mustafa
Hi guyz,
I think I did good mesh for AMI after the run case I got these messages: HTML Code:
PIMPLE: iteration 1 AMI: Creating addressing and weights between 307363 source faces and 305683 targ et faces AMI: Patch source sum(weights) min:0.00464627 max:2.23371 average:1.02594 AMI: Patch target sum(weights) min:0 max:2.3947 average:1.00556 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.0942844, No Iterations 11 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.00327133 , No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 0.0937322, No Iterations 11 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in /lib/x86_64-linux-gnu/libpthread.so.0 #3 Foam::divide(Foam::Field<double>&, double const&, Foam::UList<double> const& ) at ??:? #4 void Foam::divide<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<do uble, Foam::fvPatchField, Foam::volMesh>&, Foam::dimensioned<double> const&, Foa m::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in /usr/lib /openfoam/openfoam2012/platforms/linux64GccDPInt32Opt/bin/pimpleFoam #5 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::dimensioned<double> con st&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) in /usr/lib/openfoam/openfoam2012/platforms/linux64GccDPInt32Opt/bin/pi mpleFoam #6 ? in /usr/lib/openfoam/openfoam2012/platforms/linux64GccDPInt32Opt/bin/pimpl eFoam #7 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6 #8 ? in /usr/lib/openfoam/openfoam2012/platforms/linux64GccDPInt32Opt/bin/pimpl eFoam Floating point exception (core dumped) My case is below here: https://drive.google.com/file/d/1tBF...ew?usp=sharing Any idea to solve problem? Thanks, Regards. |
December 14, 2021, 12:35 |
Will
Rep Power: 4 |
I'm having the same problem.
Does anyone have any insight on this? |
long error when using make-install SU2_AD. | tomp1993 | SU2 Installation | 3 | March 17, 2018 06:25 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
[Gmsh] Gmsh and samplesurface | touf | OpenFOAM Meshing & Mesh Conversion | 2 | December 10, 2007 02:27 |
