Ahmed Hafez
Rep Power: 8 ![]() |
Hi everyone,
I have been working with fluent and now I try to shift to OpenFoam. I know that there are many threads that discuss this subject. However, I still bit confused with appling wall functions for komega sst model, since I don't use them in fluent. Why do i need wall function if my yplus <1. If I will apply it which one shall chose for k, omega and nut. Is the case change if I have a bit larger yplus. Thank you all. |
Herpes Free Engineer
Rep Power: 13 ![]() |
>> Why do i need wall function if my yplus <1. There is no wall-function term/modelling being applied to flow regions below yPlus=1 etc. OpenFOAM applies/switches/blends the available expressions/wall models automatically depending on spatiotemporal-variant yPlus values, so that users would not need to think/worry about yPlus - wall-function interactions. So, wall function in OpenFOAM is just all-in-one Pokémon.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
Ahmed Hafez
Thank you for your reply. Now, I understanded
so, could you help me choosing the best one for komega sst, I found: K have two types of wall function: kqRWallFunction and kLowReWallFunction Omega have only: omegaWallFunction and for nut : nutWallFunction, nutLowReWallFunction, nutUWallFunction, nutkWallFunction and nutUSpaldingWallFunction I appreciate your help. |
I don't think there is the best one. The safest option might be choosing nutUSpalding and kqRWallFunction for the multiple-choice items above.
Ahmed Hafez
Thank you for your great help
Display Modes | |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
Ansys CFD-Post Application Error | rushiCFD | FLUENT | 0 | March 21, 2021 07:51 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
Replicating Scalable Wall Function with a UDF | yousefaz | FLUENT | 0 | August 4, 2017 02:30 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
