June 28, 2021, 06:35 |
Case is not 3D or 2D, LES is not applicable
Hilaal ALAM
Hi
I am trying to simulate fireFoam with my own blcokMesh co-ordinates. I checked the mesh quality with checkMesh and found OK. However, when I run "fireFoam", I am getting the following error. Case is not 3D or 2D, LES is not applicable From function void Foam::LESModels::cubeRootVolDelta::calcDelta() in file LES/LESdeltas/cubeRootVolDelta/cubeRootVolDelta.C at line 75. Thank you in advance. |
#firefoam |
LES of channel flow: data, case files, technical report. | tiam | OpenFOAM Running, Solving & CFD | 34 | June 12, 2023 08:11 |
One of the inlets can not flow out in the case used by LES | Jingwei36 | FLUENT | 2 | April 27, 2018 09:43 |
How to set initial conditions for LES 3D case? | Derek2580 | OpenFOAM Running, Solving & CFD | 5 | April 22, 2018 02:41 |
How many BC do I need for a single LES case | wuwen | OpenFOAM Running, Solving & CFD | 0 | November 17, 2008 07:58 |
Help! Should I use LES in this case. Thanks. | Feng | FLUENT | 4 | April 25, 2008 17:04 |
