Pedro
Rep Power: 5 ![]() |
Hello everyone! I’ve been learning OpenFoam for the past two weeks and this is my first post so I would like to apologize if I dont explain myself correctly or if I ask silly questions.
I'm trying to study the effect of the wake produced by one vertical axys wind turbine in another turbine next to it (see the attached image). So, I need to achieve a flow induced rotation in both turbines. I'm able to do this with only one turbine using pimpleFoam, AMI and sixDoFRigidBodyMotion (I’m using this Holzmann tutorial as a base case: https://holzmann-cfd.com/community/t...l-wind-turbine), but I dont know how to set up the dynamicMeshDict file for more than one body since sixDoFRigidBodyMotion library is only capable to manage one body (as far as I know). I've been trying to find a way to do this in OpenFoam 8 for a week, but none of the solutions I have found work for this version, everything seems removed. Last thing I have tried is rigidBodyMotion which seems to be able to handle multiple uncoupled bodies. Here is my dynamicMeshDict file: Code:
dynamicFvMesh dynamicMotionSolverFvMesh; motionSolverLibs ("librigidBodyMeshMotion.so"); motionSolver rigidBodyMotion; report on; solver { type Newmark; } rho rhoInf; rhoInf 1.2; accelerationRelaxation 0.4; bodies { VAWT { type rigidBody; parent root; centreOfMass (0 0 0.025); mass 0.000461158*1500; inertia (0.0053176 0.0053176 0.0103473 6.898e-6 3.54533e-6 3.545e-6); transform (1 0 0 0 1 0 0 0 1) (0 0 0); joint { type Rz; } patches (VAWT); innerDistance 0.6; outerDistance 0.7; } VAWT2 { type rigidBody; parent root; centreOfMass (2.5 0 0.025); mass 0.000461158*1500; inertia (0.0053176 0.0053176 0.0103473 6.898e-6 3.54533e-6 3.545e-6); transform (1 0 0 0 1 0 0 0 1) (0 0 0); joint { type Rz; } patches (VAWT2); innerDistance 0.6; outerDistance 0.7; } } [1] #0 Foam::error: ![]() [1] #1 Foam::sigFpe::sigHandler(int) at ??:? [1] #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" [1] #3 Foam::divide(Foam::Field<double>&, double const&, Foam::UList<double> const&) at ??:? [1] #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam ![]() [1] #5 ? in "/opt/openfoam8/platforms/linux64GccDPInt32Opt/bin/pimpleFoam" [1] #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [1] #7 ? in "/opt/openfoam8/platforms/linux64GccDPInt32Opt/bin/pimpleFoam" [pedro-HP-Laptop-15s-fq1xxx:11240] *** Process received signal *** [pedro-HP-Laptop-15s-fq1xxx:11240] Signal: Floating point exception (8) [pedro-HP-Laptop-15s-fq1xxx:11240] Signal code: (-6) [pedro-HP-Laptop-15s-fq1xxx:11240] Failing at address: 0x3e800002be8 [pedro-HP-Laptop-15s-fq1xxx:11240] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x46210)[0x7f23a951d210] [pedro-HP-Laptop-15s-fq1xxx:11240] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xcb)[0x7f23a951d18b] [pedro-HP-Laptop-15s-fq1xxx:11240] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x46210)[0x7f23a951d210] [pedro-HP-Laptop-15s-fq1xxx:11240] [ 3] /opt/openfoam8/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam6divideERNS_5FieldIdEERKdRK NS_5UListIdEE+0xaf)[0x7f23aa13867f] [pedro-HP-Laptop-15s-fq1xxx:11240] [ 4] pimpleFoam(_ZN4FoamdvINS_12fvPatchFieldENS_7volMes hEEENS_3tmpINS_14GeometricFieldIdT_T0_EEEERKNS_11d imensionedIdEERKS8_+0x2f7)[0x556fec2d9c37] [pedro-HP-Laptop-15s-fq1xxx:11240] [ 5] pimpleFoam(+0x2debd)[0x556fec27eebd] [pedro-HP-Laptop-15s-fq1xxx:11240] [ 6] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf3)[0x7f23a94fe0b3] [pedro-HP-Laptop-15s-fq1xxx:11240] [ 7] pimpleFoam(+0x313fe)[0x556fec2823fe] [pedro-HP-Laptop-15s-fq1xxx:11240] *** End of error message *** -------------------------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code. Per user-direction, the job has been aborted. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpirun noticed that process rank 1 with PID 0 on node pedro-HP-Laptop-15s-fq1xxx exited on signal 8 (Floating point exception). -------------------------------------------------------------------------- I don’t have a clue on how to read this error, so I would be really grateful if someone can tell me what is happening here. Also, please tell me if I’m using the correct solvers and libraries or if there is a better way to simulate multiple body motion with 6DoF. Thank you. |
6dof, multiple ami, multiple bodies, rigidbodymotion |
Display Modes | |
Map of the OpenFOAM Forum - Understanding where to post your questions! | wyldckat | OpenFOAM | 10 | September 2, 2021 05:29 |
OpenFOAM course for beginners | Jibran | OpenFOAM Announcements from Other Sources | 2 | November 4, 2019 08:51 |
OpenFOAM 4.0 Released | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 2 | October 6, 2017 05:40 |
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin | CFDFoundation | OpenFOAM Announcements from Other Sources | 0 | January 4, 2017 06:15 |
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | January 5, 2016 03:18 |
