About limiter correction
Old   August 2, 2021, 05:00
Default About limiter correction
hbulus is on a distinguished road
In official user guide(https://cfd.direct/openfoam/user-guide/v6-fvschemes/),
If you can look at the figure 4.2 in the link, if the psi 1 it is corrected, if the psi is zero, meaning uncorrected.
Lets look at the explanation: 'Generally the uncorrected and orthogonal schemes are only recommended for meshes with very low non-orthogonality (e.g. maximum 5∘).
The corrected scheme is generally recommended, but for maximum non-orthogonality above 70∘, limited may be required
Everything, makes clear until now except this sentence :'Typically, psi is chosen to be 0.33 or 0.5, where 0.33 offers greater stability and 0.5 greater accuracy.' This sentence sounds wrong to me, i think it should be opposite.
Anyway, if you can look at this link(http://www.wolfdynamics.com/wiki/tipsandtricks.pdf) at slide 25, he says that psi should be 0 for bad meshes, should be 1 for good meshed.
These both sayings conflict with each other. Which one is correct or are there something that i totally miss ?
Thanks
hbulus is offline   Reply With Quote
Old   August 2, 2021, 07:23
geth03 is on a distinguished road
i am not an expert with regards to that particular issue, but if you look closer at the slides, you see that you have basically 2 options:
1: corrected 2: limited psi
on the website you have 5 entries, the entries with psi are slightly different:
-> limited corrected psi
maybe that 'corrected' somewhat changes what the scheme does and it is then not contradictory at all.
correct me if i miss something.
geth03 is offline   Reply With Quote
Old   August 2, 2021, 08:19
Yes, i thougt as you do but still it cant be claimed as %100 true because i am confused a bit.
Old   August 2, 2021, 09:00
Michael Alletto
mAlletto will become famous soon enough
I recommend read this book https://www.springer.com/gp/book/9783319168739
To have inside about the numerics in OF. Generally corrected means non orthogonal corrections and limited are limiters to avoid oscillation of the variables when interpolating from the cell centers to the face centers
mAlletto is offline   Reply With Quote
Old   August 2, 2021, 09:19
I'll check if i can find the book. Thank you.
Do you have any idea about my confusion ?
viscosity udf don't use correct temperature and strain rate rezvani Fluent UDF and Scheme Programming 8 May 27, 2021 05:40
Fail to converge when solving with a fabricated solution zizhou FLUENT 0 March 22, 2021 06:33
Minmod limiter for Correction Procedure via Reconstruction LUQILIN Main CFD Forum 0 May 20, 2016 02:36
Production correction or curvature correction in the SST model Ang CFX 2 May 20, 2014 20:50
Warning 097- AB Siemens 6 November 15, 2004 04:41
