OF div schemes greatly influence the result
Like Tree2Likes
  • 1 Post By hjasak
  • 1 Post By piu58
Old   January 30, 2021, 00:11
Default OF div schemes greatly influence the result
samuel
Samuel Twain is on a distinguished road
Dear all:
I'm doing a simulation about wind aroud a flat roof. The model can be seen below.
[image]https://www.cfd-china.com/assets/uploads/files/1611984747439-wholemodel.png[/img]
In the reference paper, the author applied 'second order upwind' for space discretization in Fluent. And I have used the same model parameters (eg. domain size, minimum element size, boundary condition, turbulence model). simpleFOAM and realizable k-epsilon model are used. However I find that if I adopt different divergence schemes (namely, gauss upwind, linearUpwind and limitedLinear), the results will be different from each other and only the result of 'gauss upwind' agrees with that of reference paper.
From what I gather, in openfoam 'gauss linearUpwind' represents 'second order upwind' which was adopted in the reference paper. But when I use 'gauss linearUpwind' for the divergence schemes in OpenFOAM, the simulated result (namely, friction velocity on roof) differs greatly from that of reference paper. In comparison, the performance improves if I adopted 'gauss upwind' which represented first order upwind. The results of different div schemes can be seen below.
[image]https://www.cfd-china.com/assets/uploads/files/1611984885997-0f0345fa-d59b-4030-9578-0dcb60ab0d6f-image.png[/img]
To describe my question detailedly, some details of my fvSchems and fvSolutions are also posted.
ddtSchemes
    default         steadyState;
gradSchemes
    default         Gauss linear;
    limited         cellLimited leastSquares 1;
    //grad(U)         $limited;
    grad(k)         $limited;
    grad(epsilon)     $limited;
divSchemes
    default         none;
    div(phi,U)      Gauss limitedLinear 1;//bounded Gauss linearUpwind limited, Gauss upwind;
    turbulence      bounded Gauss linearUpwind limited;
    div(phi,k)      $turbulence;
    div(phi,epsilon) $turbulence;
    div((nuEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
wallDist
    method meshWave;
solvers
    p
        //solver          PCG;
        //preconditioner  DIC;
        solver          GAMG;
        tolerance       1e-7;
        relTol          0.1;
        smoother        DICGaussSeidel;
    "(U|k|epsilon|omega)"
        solver          PBiCGStab;
        preconditioner  DILU;
        //solver          smoothSolver;
        //smoother        symGaussSeidel;
        tolerance       1e-7;
        relTol          0.001;
SIMPLE
    nNonOrthogonalCorrectors 2;
    consistent      yes;
    residualControl
        p               1e-7;
        U               1e-7;
        "(k|epsilon|omega|f|v2)" 1e-7;
relaxationFactors
    fields
        p               0.3;
    equations
        U               0.7;
        "(k|omega|epsilon).*" 0.7;
Actually, in many papers, first order upwind scheme are not encouraged to use. But in my simulation, it seems that I have to choose 'gauss upwind' to get a 'right' result compared with reference papar of which the author has adopted second order upwind schemes. And higher-order div schemes lead to something wrong.
That makes me confused. Could anyone please give me some suggestions?
Thank you
samuel
Samuel Twain is offline   Reply With Quote
Old   January 31, 2021, 12:28
Hrvoje Jasak
You are using the wrong kind of schemes on bounded scalars - this will destabilize the solver.
If numerical diffusion is causing trouble, you can simply refine the mesh.
Hrv
saeed jamshidi likes this.
Hrvoje Jasak
Old   February 1, 2021, 03:05
samuel
Hrv
Thank you, Hrv. I will remove "bounded" , refine the mesh and find out whether it will cause peoblems.
Before that, I have found that my “k” boundary type seems to be unreasonable. Originally, I used kLowReWallFunction, after changing it to kqrWallFunction, the result becomes better.
This also makes me confused. According to description, kLowREWallFunction is suitable for both low and high RE condition, while kqrWallFunction is only for high RE condtion. Is kLowREWallFunction unsuitable for realizable k-epsilon turbulence model?
Old   August 2, 2021, 07:18
hbulus is on a distinguished road
Hrv
You mean limitedLinear would be better for scalars, and linearUpwind for U, right ?
hbulus is offline   Reply With Quote
Old   August 2, 2021, 10:38
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
You may use Gauss upwind if you are looking for robust schemata. More accurate is linear upwind, but more oscillatory too.
hogsonik likes this.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
chtMultiRegionSimpleFoam div schemes guserik OpenFOAM Running, Solving & CFD 2 November 14, 2013 17:30
simpleFoam: case only converges with most div schemes set to upwind buffi OpenFOAM Running, Solving & CFD 7 November 11, 2013 07:54
Numerical schemes for grad and div Tobi OpenFOAM 6 March 11, 2013 21:24
Accuracy problem of HO schemes on unstructured mesh, HO scheme gives 1st order result gemini Main CFD Forum 12 December 27, 2011 21:01
time stepping schemes for compressible DNS/LES shyamdsundar Main CFD Forum 0 January 14, 2010 23:15
