cannot find patchField entry
Old   August 18, 2021, 11:18
Default cannot find patchField entry
Thibo
thibogoddef is on a distinguished road
Hello for my flow over an airfoil simulation i get the following error:
Reading field U
-->FOAM FATAL IO erro:
Cannot find patchField entry for airfoil....
My boundry file looks like this:
outlet
type outlet;
nFaces 132;
startFace 28303;
inlet
type inlet;
nFaces 216;
startFace 28435;
airfoil
type wall;
inGroups 1(wall);
nFaces 70;
startFace 28651;
frontAndBackPlanes
type empty;
inGroups 1(empty);
nFaces 28512;
startFace 28721;
And my U file (where I guess there is a problem):
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
outlet
type zeroGradient;
inlet
type fixedValue;
value uniform (19 2 0)
airfoil
type noSlip;
frontAndBackPlanes
type empty;
Does anyone know how to solve this error?
Kind regards TG
thibogoddef is offline   Reply With Quote
Old   August 18, 2021, 11:22
Yann
Yann will become famous soon enough
Hi Thibo,
It seems you are missing a semicolon on the inlet BC:
inlet
    type fixedValue;
    value uniform (19 2 0);
Regards,
Yann
Yann is offline   Reply With Quote
Old   August 18, 2021, 11:35
Thibo
Hi Yann
Thanks for the quick reply
After this I get the same cannot find patchField entry for airfoil, but now after it says:
Selecting RAS turbulence model SpalartAllmaras
A little further it mentions the nut file, is there anything wrong with this one?
Nut file:
dimensions [0 2 -1 0 0 0 0];
internalField uniform 0.14;
boundaryField
outlet
type zeroGradient;
inlet
type fixedValue;
value uniform 0.14;
airFoil
type nutUSpaldingWallFunction;
value uniform 0;
frontAndBackPlanes
type empty;
Nut tilda file:
boundaryField
outlet
type zeroGradient;
inlet
type fixedValue;
value uniform 0.14;
airfoil
type fixedValue;
value uniform 0;
frontAndBackPlanes
type empty;
I checked the semicolons but can't find any other fault, can you help me with this aswell?
Kind regards TG
Old   August 18, 2021, 11:40
Yann
Yes, you have a typo in the nut file: airFoil instead of airfoil.
These are typical and pretty straightforward errors. Every time you get it, it means there is something wrong in the file: missing or extra semicolon or bracket, wrong name, etc...
Cheers,
Yann
Old   August 18, 2021, 11:56
Thibo
I guess you can see I'm just getting started with OpenFOAM.
Thanks again Yann for the reply!
Kind regads TG
Cannot find patchField entry for InletWall range_rover OpenFOAM Running, Solving & CFD 5 November 18, 2020 21:21
Parallel snappyHexMesh problem: Cannot find patchField entry for procBoundary2to7 hconel OpenFOAM Pre-Processing 0 October 5, 2018 17:22
decomposePar fails "Cannot find patchField entry for maxY" JasonQuinn OpenFOAM Pre-Processing 2 April 4, 2017 01:07
adding compressible option to ptot immortality OpenFOAM Programming & Development 13 June 15, 2015 15:00
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 12:38
