why do I get velocity entering a wall boundary? |
August 19, 2021, 21:33 |
Zach
Rep Power: 4 |
Hello, I'm a beginner on openFoam. I downloaded an application called gravityCurrentFoam from here https://github.com/psu-efd/gravityCurrentFoam. There is a case in the repo which simulating gravity current in a rectangular flume. In that case, there is a hole (inlet) on the bottom of the flume which is represented as a boundary with a fixed inflow velocity. Now I'm modifying that case to simulate another experiment from a paper. I deleted that boundary but still found velocity around that area.
The case I'm working on is here. https://github.com/bhqasx/Learning-openFoam-case |
August 20, 2021, 01:18 |
Uwe Pilz
Rep Power: 15 |
As far as I see you have fixed value for all boundaries for U.
Normally this is not recommended. If you use it, inflow and outflow have to contain the same volume stream. That is not the case, as far as I can see.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
September 10, 2021, 09:11 |
Zach
Rep Power: 4 |
Thanks Pilz. I have added an outlet with fixed pressured and the problem is fixed.
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
why do I get velocity entering a wall boundary? | bhqasx | OpenFOAM Running, Solving & CFD | 0 | August 19, 2021 21:19 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 17:30 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
